« 1 (2)
Re: 120Y Ute - photos
1. South Africa bakkie bench
2. B20 Datsun 1000 ute bench
3. Swap in another, such as Datsun 320 truck (but the 320 bench is narrower)
Posted on: 2012/6/27 0:19
Here's a press photo
* 5-slot DX hubcaps
* reflectors on the grille
* wing mirrors, but not the JDM ones
except for the hubcaps, it looks like this one from a 1974 movie (which makes the movie car pre-120Y)
jpg  120Y pick-up.jpg (126.48 KB)
174_6196348d4018c.jpg 1200X720 px
Posted on: 2021/11/18 11:10
Here is what the rear badge 120Y looks like, photo from club member crashed
jpg  _mg_7238.jpg (51.48 KB)
174_6196afc94a0a4.jpg 800X600 px
Posted on: 2021/11/18 19:55
And there's those mirrors
120Y bakkie flyer
it has the 120Y style front indicators
SPECIFICATIONS
DIMENSIONS AND WEIGHTS:
Overall length 3 845 mm
Overall width 1 495 mm
Overall height 1 395 mm
Wheelbase 2 300 mm
Tread (front) 1 250 mm
Tread (rear) 1 245 mm
Minimum ground clearance 160 mm
Rear body interior length 1 565 mm
Rear body interior width 1 285 mm
Rear body interior height 410 mm
Gross vehicle mass 1 400 kg
Vehicle mass (tare) 696 kg
Seating 3 persons
PERFORMANCE:
Maximum speed 140 km/h
% gradient at full load 32,6%
Minimum turning radius 4,1 m
ENGINE:
Type: Petrol engine, 4 cycle, 4 cylinder
in-line, OHV, water-cooled. Bore and
Stroke: 73 x 70 mm.
Displacement 1 171 cm3
Compression ratio 9,0 to 1. Maximum
power 49 kW @ 6 000 r/min.
Maximum torque 93 Nm @ 3 600
r/min.
FUEL SYSTEM:
Carburettor: dual barrel, down draught
Fuel pump: mechanical type diaphragm pump.
Fuel tank capacity: 37 litres.
Fuel consumption: *6,2l per 100 km at 80 km/h.
* Car magazine figure.
LUBRICATION SYSTEM:
Lubrication method: pressure feed,
full flow.
ELECTRICAL SYSTEM:
Battery: 12 volt 45 Ah. 35A
alternator with regulator.
TRANSMISSION:
4-speed manual full synchromesh with
floor change. 1st-3,757; 2nd-2,169;
3rd-1,404; 4th-1,00; Reverse-3,640;
Final drive-4,11:1.
BRAKES:
Tandem master cylinder, dual brake
circuit; drum brakes front and rear.
Total lining area 546,0 cm2
SUSPENSION:
Front: Independent strut type with coil
springs, tension rod and stabilizer.
Rear: Live axle with semi-elliptical
leaf springs and telescopic
double-acting shock absorbers.
NOTE: These specifications are
subject to change without notice.
1. Sidemounted turning indicator repeaters.
2. 500 x 12,6 ply tyres.
3. Under-bumper side lights and turning indicators
4. 2-speed windscreen wipers and washers.
5. Twin outside rear mirrors.
6. Padded dash and non-glare instrumentation.
OTHER STANDARD FEATURES INCLUDE:-
Lockable fuel filler flap.
Rear window protection bars.
Double side & tail gate panels on load box.
Load tie down hooks.
Glove box.
Parcel tray,
High quality moulded floor carpet.
Interior lamp.
Two sunvisors/bench seat covered in long lasting vinyl material.
OPTIONS:-
Date issued: Sept. 1978 Order No.: L-0-001/78
The choice of 2 "Dazzle Datsuns" — The "Van der Merwe" and "Bester" — both making these the only bakkies available, direct from your dealer with such as:-
Magnesium road wheels.
Radial ply tyres.
Sporty "Dazzle" body stripes
Black-out front bumper and fender mirros.
Tonneau cover.
DATSUN
GREAT FEATURES MAKE DATSUNS GREAT.
DATSUN NISSAN
jpg  1 Sidemounted turning indicator repeaters.jpg (67.28 KB)
174_6197da008c0d6.jpg 751X393 px
jpg  2 5.00x12, 6-ply tyres.jpg (103.63 KB)
174_6197da0b4c869.jpg 750X792 px
jpg  3 Under-bumper side lights and turning indicators.jpg (48.08 KB)
174_6197da167f84a.jpg 751X313 px
jpg  4 2-speed windscreen wipers and washer.jpg (45.41 KB)
174_6197da4f292a3.jpg 500X404 px
jpg  5 twin outside rear mirror.jpg (154.52 KB)
174_6197da65aa16c.jpg 748X1044 px
jpg  6 Padded dash and non-glare instrumentation.jpg (106.59 KB)
174_6197da744c789.jpg 798X706 px
Posted on: 2021/11/19 17:11
« 1 (2)
