Browsing this Thread:
1 Anonymous Users
Re: 120Y Ute - photos |
Registered Users Contentmaster Usermaster
1. South Africa bakkie bench 2. B20 Datsun 1000 ute bench 3. Swap in another, such as Datsun 320 truck (but the 320 bench is narrower)
Posted on: 2012/6/27 0:19
Here's a press photo * 5-slot DX hubcaps * reflectors on the grille * wing mirrors, but not the JDM ones except for the hubcaps, it looks like this one from a 1974 movie (which makes the movie car pre-120Y)
120Y pick-up.jpg (126.48 KB)
Posted on: 2021/11/18 11:10
Here is what the rear badge 120Y looks like, photo from club member crashed
Posted on: 2021/11/18 19:55
And there's those mirrors 120Y bakkie flyer it has the 120Y style front indicators  Quote: SPECIFICATIONS DIMENSIONS AND WEIGHTS: Overall length 3 845 mm Overall width 1 495 mm Overall height 1 395 mm Wheelbase 2 300 mm Tread (front) 1 250 mm Tread (rear) 1 245 mm Minimum ground clearance 160 mm Rear body interior length 1 565 mm Rear body interior width 1 285 mm Rear body interior height 410 mm Gross vehicle mass 1 400 kg Vehicle mass (tare) 696 kg Seating 3 persons
PERFORMANCE: Maximum speed 140 km/h % gradient at full load 32,6% Minimum turning radius 4,1 m
ENGINE: Type: Petrol engine, 4 cycle, 4 cylinder in-line, OHV, water-cooled. Bore and Stroke: 73 x 70 mm. Displacement 1 171 cm3 Compression ratio 9,0 to 1. Maximum power 49 kW @ 6 000 r/min. Maximum torque 93 Nm @ 3 600 r/min.
FUEL SYSTEM: Carburettor: dual barrel, down draught Fuel pump: mechanical type diaphragm pump. Fuel tank capacity: 37 litres. Fuel consumption: *6,2l per 100 km at 80 km/h. * Car magazine figure.
LUBRICATION SYSTEM: Lubrication method: pressure feed, full flow.
ELECTRICAL SYSTEM: Battery: 12 volt 45 Ah. 35A alternator with regulator.
TRANSMISSION: 4-speed manual full synchromesh with floor change. 1st-3,757; 2nd-2,169; 3rd-1,404; 4th-1,00; Reverse-3,640; Final drive-4,11:1.
BRAKES: Tandem master cylinder, dual brake circuit; drum brakes front and rear. Total lining area 546,0 cm2
SUSPENSION: Front: Independent strut type with coil springs, tension rod and stabilizer. Rear: Live axle with semi-elliptical leaf springs and telescopic double-acting shock absorbers. NOTE: These specifications are subject to change without notice.
--------------- 1. Sidemounted turning indicator repeaters. 2. 500 x 12,6 ply tyres. 3. Under-bumper side lights and turning indicators 4. 2-speed windscreen wipers and washers. 5. Twin outside rear mirrors. 6. Padded dash and non-glare instrumentation. ---------------
OTHER STANDARD FEATURES INCLUDE:- Lockable fuel filler flap. Rear window protection bars. Double side & tail gate panels on load box. Load tie down hooks. Glove box. Parcel tray, High quality moulded floor carpet. Interior lamp. Two sunvisors/bench seat covered in long lasting vinyl material.
OPTIONS:- Date issued: Sept. 1978 Order No.: L-0-001/78 The choice of 2 "Dazzle Datsuns" — The "Van der Merwe" and "Bester" — both making these the only bakkies available, direct from your dealer with such as:- Magnesium road wheels. Radial ply tyres. Sporty "Dazzle" body stripes Black-out front bumper and fender mirros. Tonneau cover.
DATSUN GREAT FEATURES MAKE DATSUNS GREAT.
DATSUN NISSAN
Posted on: 2021/11/19 17:11
