« 1 2 3 4 (5) 6 »
Re: DEMAC's 1200 Sedan
From MOOROODUC. Victoria
I moved the shell from the back shed to the front shed to test fit the engine and bought a BW78 diff to get shortened.
pictures a plenty many with measuring the space left in the engine bay (available on request) ... here's a few ... oh and you can also see where the standard gearshift will come out :)
jpg  in workshop.jpg (22.54 KB)
8710_631d860f4236e.jpg 309X296 px
jpg  newish diff.jpg (36.79 KB)
8710_631d8623b5e95.jpg 327X440 px
jpg  newish diff2.jpg (16.88 KB)
8710_631d862ce229c.jpg 317X189 px
jpg  SR20 in Engine Bay 1.jpg (19.56 KB)
8710_631d863a2f42a.jpg 300X304 px
jpg  SR20 in Engine Bay 2.jpg (28.55 KB)
8710_631d8641d17d6.jpg 355X355 px
jpg  SR20 in Engine Bay 3.jpg (18.82 KB)
8710_631d864bbe8f6.jpg 359X359 px
jpg  SR20 in Engine Bay 4.jpg (21.78 KB)
8710_631d8653428c2.jpg 386X386 px
jpg  SR20 in Engine Bay 5.jpg (11.39 KB)
8710_631d865c6ce5d.jpg 250X250 px
jpg  SR20 in Engine Bay 6.jpg (19.68 KB)
8710_631d8664e87b5.jpg 436X436 px
jpg  gear shift location1.jpg (20.81 KB)
8710_631d866dea4f6.jpg 371X371 px
jpg  gear shift location2.jpg (22.64 KB)
8710_631d8683a6223.jpg 350X350 px
Posted on: 2022/9/11 7:56
Online
Nice
that diff looks like what Chevrolet Camaro came with in 1987, including the finned alloy calipers. they called it "the australian 9-bolt axle"
Posted on: 2022/9/14 7:42
Online
thanks for the pics
Your floor tunnel looks like an automatic tunnel what with the square opening and the four screw holes for the console
The new shifter hole needs to be centered about? 4" aft of the center of the original 1200 automatic shifter hole?
i used STGthumb for windows to get these down to a postable byte size (same resolution as before).
jpg  automatic shifter hole and S13 shifter top plate 20220910_151707.jpg (141.78 KB)
174_63376d7ca5f2c.jpg 1200X1200 px
jpg  S13 shifter plate sitting on strut tower The bolt pattern width ~82mm center-to-center 20220910_151424.jpg (113.79 KB)
174_63376d88456d4.jpg 1200X1200 px
jpg  20220910_151808.jpg (164.41 KB)
174_63376d93351df.jpg 1200X1200 px
jpg  20220910_151751.jpg (183.14 KB)
174_63376da376b19.jpg 1200X1200 px
jpg  20220910_151605.jpg (114.98 KB)
174_63376dae96643.jpg 1200X1200 px
Posted on: 2022/9/30 23:29
I didn't like the angle that the gearbox and motor were on and the fact that the dump pipe was fouling so - out with the angle grinder and the welder
Forgive my bird poo welds .... they will get a clean up later. The positioning on the engine cross member hasn't changed but the angles have.
Also test fitted the shortened Diff that I got back on Thursday.
the last photo is the distance between the diff (where I have it at the moment) and the back of the standard 180SX S13 g'box ...the shifter comes out directly between the (driver/passenger) front seat mounts
jpg  gbox raised measure1.jpg (76.70 KB)
8710_6394f607a3976.jpg 756X756 px
jpg  gbox raised measure2.jpg (68.84 KB)
8710_6394f614d0247.jpg 756X756 px
jpg  gbox raised measure3.jpg (66.23 KB)
8710_6394f623e0c12.jpg 756X756 px
jpg  gbox raised 1.jpg (75.90 KB)
8710_6394f6359c17f.jpg 756X756 px
jpg  diff test fit 1.jpg (117.12 KB)
8710_6394f642c4b7d.jpg 756X756 px
jpg  diff test fit 2.jpg (122.69 KB)
8710_6394f651bfcf7.jpg 756X756 px
jpg  distance between gbox and diff flange.jpg (91.34 KB)
8710_6394f667336fa.jpg 756X756 px
Posted on: 2022/12/10 21:15
So the Auto transmission tunnel mounts almost line up with the S13 Manual Gearbox ... just made up this crossmember to fit it up
jpg  GBox Xmember.jpg (101.94 KB)
8710_63ae7fee7911c.jpg 756X756 px
Posted on: 2022/12/30 6:07
Bling alert!
Courtesy of Supafatto (many thanks and great job!) these bad boys are destined for the new build
I have the H74 ball joints ... just sorting out the bearings.
One thing bugging me is the intake plenum .... making sure it misses the MADDAT clutch reserve ... hmmmm
jpg  Struts.jpg (60.55 KB)
8710_63d59a616629b.jpg 378X674 px
Posted on: 2023/1/28 21:57
Nice! Gotta love a Supafatto coil over setup.
As for intake, unlike the CA18, there are some cheapish aftermarket option like Greddy copies that
may give you more clearance.
Otherwise, if you want even more bling and 2.5k less in your bank account check out the Plazmaman ones.
https://golebysparts.au/search?q=Sr20*%20intake*&type=article,page,product
Posted on: 2023/1/29 2:17
More mocking up before the engine and tranny come back out and prep/paint
need to cut a bit out of the front valence panel to bring the intercooler forward as much as possible without showing it too much
Also ... the MADDAT clutch master fits and just misses the intake manifold ... whew - didn't really want to spend another grand on an intake plenum
jpg  Intercooler mock 1.jpg (112.21 KB)
8710_63e6f7cbe4aeb.jpg 756X756 px
jpg  Intercooler mock 2.jpg (141.17 KB)
8710_63e6f7e5a3f14.jpg 756X756 px
jpg  Engine & clutch mockup 1.jpg (85.72 KB)
8710_63e6f7f81352d.jpg 756X756 px
jpg  Engine & clutch mockup 2.jpg (114.31 KB)
8710_63e6f80291e4b.jpg 756X756 px
Posted on: 2023/2/11 2:08
Online
Nice pictures!
Looks like it will be a lot of fun to drive
Posted on: 2023/2/11 22:42
Looking the goods :)
Posted on: 2023/2/15 9:09
Car free
« 1 2 3 4 (5) 6 »
