(1) 2 3 »
Swiss Cheese '71 B110 (reclaiming my youth)
From Brisbane, QLD
I miss the days of this forum/forums in general
Thank goodness the Techwiki is still alive and running as I always find something new to learn, especially coming from 76'-91' 1200 Utes and stepping into the world of a '71 1200 Sedan.
Not too much of a story but I love a yarn.
Over the years have seen 1200's around, got to drive one around a workshop that a friend was fixing up for a client 18 months ago, as you all know there is no getting rid of the Datsun bug.
A friend purchased this Sedan from somewhere outside of Ipswich and fixed a few things up to get it on and off a trailer. He was sick of dealing with Facebook Marketplace and I was toying with the idea of getting a Long-Term project. I quickly realised that a) 1200 Ute Shells are exxy compared to when I was last looking and b) I'm getting too old and stiff (28) to be cramming myself into a Ute cabin.
Worked out a deal with him trading cash, my wiring skills and the use of his trailer to transport it back to my workplace to sit in the corner of the yard (until I have room at home to move it to) and that's pretty much the origin story.
General idea for this car, spend far too much time reviving this shell, make it into a comfy Saturday morning Cruiser so I can take my Mrs and my little doggo to get Eggs Benny in the morning as my drift car is far too rowdy nowadays for them
She's definitely had a hard life but I wanted something long term so here I am. Here is how it looked when I towed it to work on the 5th of Feb. Hot tip, it doesn't look any different now.
Where it currently resides until I have room at home
Original ignition keys and door keys had been lost, a previous owner had attacked the ignition barrel with a screwdriver, which ended up not being successful and embedding a piece of metal in the teeth, and levered off the column to allow the steering wheel to unlock. I made a makeshift ignition system for the car to move it around and verify things working. It does drive, shifted from P into D and R perfectly fine, but had no brakes so made use of the surprisingly good handbrake to slow it up.
It didn't have any carpet in it which made life easier spotting rust and any issues it has. Cockroaches and little beetles weren't too stoked about me cleaning the interior out which I found out quickly
Further pulled down the interior, removed the Dashboard and the Heaterbox. At some stage the heaterbox plastics must have failed and it had a rag jammed into the fan cavity which a family of Rats had made a home in at some stage in the cars life. Removing the dashboard made the rust in the waterbox/firewall evident which wasn't surprising considering the car is 50+ years old and it spent a good part of its life outside being neglected
At some stage, someone tried jacking the car up but either didn't locate the sill pinchweld or the whole floor gave out, because its been pushed into the car as seen in photos
Motor was full of crap as expected, unsure how it ever ran to be honest. Ripped the thermostat out, scooped as much gunk and corrosion out as I could and filled the system with Vinegar and let it sit for a few hours. Ended up skulldragging it into the washbay at work and letting it sit there for a while with water flowing through the system via a hose. It seemed to free up a lot of crap that was within the motor but I am not holding too much hope for it, it will get removed once day in place of something else.
Found a set of almost new 12" tires to slap onto the factory steelies, they are comically small compared to my stock Hilux wheels
I did this to reliably be able to move it around as the old tires were properly dry rotted and leaking air out of every place they could. I moved it inside during Cyclone Alfred because lets be honest, if a car was going to get damaged during the cyclone, it wouldn't be one of the 1000 brand new cars around it, it would be the Datsun . This was also my attempt at putting some good Juju out into the Datsun Universe to help me with what is to come with the rebuild
The Locksmith my workplace uses was very helpful in rejuvenating my ignition barrel and door locks. I purchased a Tub load of spare sedan parts off someone down the coast and in the load was a set of doors. I used these locks in conjunction with my original locks to make a single working pair which were keyed to each other. They also cut me a key to suit the original ignition barrel which oddly makes me happy that I am able to continue using it, even though it has definitely seen better days.
The end result of my little month plus long endeavor, two working door locks with new Nylon Rod Holders and a working Ignition Barrel with fresh keys for all three. Even managed to find the original boot lock (which looks like it was levered out of the boot with a lever) which works with the news keys I had cut (as they are cut to the original code for the vehicle)
I find it comical that I focused so hard on getting working locks etc for a car that currently looks like brown swiss cheese, but it itched a spot in my brain. Here's a few more photos of the cars rust, haven't been game enough to remove front panels yet but surprisingly the engine bay and frame rails (both in the engine bay and underneath at the back of the car) look good. The boot/spare tire area are a definite cut and replace job but that is a future job for me
I'll upload some photos in posts to come as I comb through my phone.
At the moment nothing in particular has happened to the Sedan but I am excited to get into this project soon. Snagged a Dashboard with limited cracking/decay in the dash pad (just needs to be recovered) with a Coupe Dash Insert including an almost perfect condition OEM Tachometer for $60 a suburb away from me which was unreal.
Final Edit to resize photo's
Posted on: 4/9 3:58
Edited by torino120 on 2025/4/9 4:50:15
Edited by torino120 on 2025/4/9 4:57:16
Edited by torino120 on 2025/4/9 5:13:35
Edited by torino120 on 2025/4/9 5:15:59
Edited by torino120 on 2025/4/9 5:21:16
Edited by torino120 on 2025/4/28 1:59:23
Edited by torino120 on 2025/4/28 2:01:14
Edited by torino120 on 2025/4/28 2:05:06
Edited by torino120 on 2025/4/28 2:08:33
Edited by torino120 on 2025/4/28 2:10:11
71 B110
Re: Swiss Cheese '71 B110 (reclaiming my youth)
A bit of rust, but she's straight, inshe? that's a nice project, and i've always been partial to sunshine white
jpg  tumblr_36c72feab3b0cf5ad5a2ea2ff618d4f5_9f53457d_2048.jpg (126.76 KB)
174_67f60ab00c9ae.jpg 1088X640 px
jpg  tumblr_33392ed8e962a39be6c51137f4422966_2229672d_2048.jpg (115.57 KB)
174_67f60ac7c0ee8.jpg 1088X640 px
jpg  tumblr_a3fb3c6eeb4b4aad6b1c3901b5dc4bcc_d732f319_2048.jpg (122.40 KB)
174_67f60ad3cd05e.jpg 800X600 px
Posted on: 4/9 6:51
From Brisbane, QLD
If there is one thing I can say, is that apart from someone's attempt at forced entry into the Boot, it is straight and accident free
Haven't had a chance to look at colours for Aussie Sedans but it has this sticker
Took some more photos the other day which I will chuck in here, it will be a long road but I am looking forward to it
Also a nice little indicator of the cars history, old school (weird to think 2005 was 20 years ago) Rego Sticker
Needs some love around the original lock hole but does the trick at this stage
Posted on: 4/14 3:26
Edited by torino120 on 2025/4/14 3:44:42
Edited by torino120 on 2025/4/28 2:12:31
Edited by torino120 on 2025/4/28 2:13:18
71 B110
From Brisbane, QLD
Seems bang on looking at the Australian Market Colours, 12330 Antarctia White
Posted on: 4/14 4:52
71 B110
oh i forgot about the sedan being assembled locally. The DULON 12230 "Antartica White" looks pretty much like the Coupe color #821 Sunshine White/Pale Gray which my sedan had
and nice overhead shot, it's not a view you see every day
jpg  DULON 566-12330.jpg (76.38 KB)
174_67fe0b6678e9a.jpg 752X384 px
jpg  overhead.jpg (193.42 KB)
174_67fe0d35466be.jpg 928X1040 px
Posted on: 4/15 8:39
From Brisbane, QLD
torino120 wrote:
Found a set of almost new 12" tires to slap onto the factory steelies...
Thought I'd chuck photo's up of these, smallest wheels I've had on the machine at work and they definitely made me work to get them off
Did a Release of Information Request for the vehicle to get some vague history about the cars registration, poor girl hasn't seen a road in 20 years.
I only have its Queensland History starting from 21st of January, 1985. Whether its prior history was lost in the system and its always been in QLD, or it started its life in another state, I don't have the rest of the history but it would be cool to find it out
The same plates it was cancelled with in 2005 are still on it now, so the car hasn't done much (apart from rust) in the last 20 or so years it seems
Posted on: 4/16 5:58
Edited by torino120 on 2025/4/28 2:13:56
71 B110
I find it interesting that it shows the insurance payments. Over here it is required by law to operated, but since not required to register each year, about 22% drive uninsured
Where you live, is it separate title (for ownership) and road registration every year? In USA these are two different things
Posted on: 4/16 20:41
From Brisbane, QLD
Much like the US, things differ state to state. Aus wide you pay CTP (Compulsory Third Party insurance) when you pay for your registration renewal. They also lump in Road Tax and all that crap which doesn't seem to go anywhere because our roads are still cactus
In Queensland you need a Roadworthy only when initially registering an unregistered vehicle, transferring the registration into another persons name, or transferring an interstate vehicle to QLD registration.
I think (don't quote me, I only lived in NSW until I was 12yo), in NSW they have Blue Slips to initially register and/or transfer ownership of the vehicle, and a yearly Pink Slip (roadworthy) if the vehicle is over 5 years old
This is why there are a few absolute bombs driving around QLD as you only need to get a roadworthy once in the cars life under you ownership if you keep paying the registration. Technically speaking, if the previous owner kept the registration going on the 1200 Sedan, he could have been driving it today under the same roadworthy it got back in 2000
Other states, who knows, I can only google so much while I am at work
Every state has yearly registration as a maximum term
Posted on: 4/16 22:51
71 B110
Thanks. Very few states here have annual inspections. So most cars have NEVER been inspected, nor are they required to be inspected. And yet it's extremely rare for accidents to occur due to equipment failure. Even the periodic emissions inspections Washington used to require has ended
In Hawaii they did have annual inspection, but they only check:
* all lights and horn work
* check-engine light is not on
* tires have legal tread
* windows are un-tinted (which keeps the tinting shops busy all the time)
Any amount of rust is OK, holes in the door, etc. is no problem
It makes more sense what your state does, require proof of insurance at the yearly registration. When there are accidents here, often he is illegally driving uninsured. So, we get insurance for their non-insurance. It's a mess!
Posted on: 4/17 9:07
can you tell us more about this push-to-start setup?
The ol' Water Box Rust
jpg  ignition_toggle.jpg (73.40 KB)
174_6806f1d31fca4.jpg 560X960 px
jpg  water_box_rust.jpg (141.38 KB)
174_6806f2280604e.jpg 1024X768 px
Posted on: 4/22 2:35
(1) 2 3 »
