any suggestions on building custom spark plug wires for EDIS?
The boot for a stock Datsun distributor is a LOT smaller than the one for an EDIS ignition module. I'm thinking about a good way to set this up. Maybe buy a set of Ford ignition wires, cut them down, and crimp on spark plug ends? Maybe just get plugs from like a 90's Fiesta? Anyone done this and have suggestions for what worked well?
Posted on: 2025/4/20 0:10
Re: any suggestions on building custom spark plug wires for EDIS?
Couple of choices
* Using Ford EDIS 4-cyl coil pack, use 1990 Escort plug wires
* Use two Buick 3800 coil packs
My setup with the Escort wires:
RockAuto wires
Posted on: 2025/4/20 9:16
I've ordered a set of wires. Woo hoo! Thanks!
Posted on: 2025/5/1 4:10
wait order these instead, guys done his research and link
for his EDIS project should have all the stuff he used!
Cleanest Ive seen on a Datsun and inspired me to go this route one day
for my qr25 headed SR20 with quad 45mm bike carbs, still in the works :)
I got all the parts just need time! check out the bling just beautifilled!!!!
Its another Jaffa Datto but wow!
https://www.msextra.com/forums/viewtopic.php?t=37758
Posted on: 2025/5/3 2:27
Those plug wires look like a Ford item but a bit shorter than the Escort ones, where the coil was on the end of the cylinder head
Posted on: 2025/5/3 7:43
That is one fine looking build. Mine will never be that sorted looking.
Posted on: 2025/5/3 21:31
I believe they mounted the coil pack right over the distributor hole. I've seen several EDIS builds that did that
Posted on: 2025/5/4 0:46
I'd like to mount the edis pack on the firewall. The reason is because I'd like to put a supercharger roughly where the distributor is now. However, there's a dipstick in the way and I haven't yet figured out how to deal with that. But like there is just no way there's room for a supercharger on the intake side.
Posted on: 2025/5/4 3:29
dipstick near the firewall. is this a 1200?
My EDIS plug wires were long enough to mount the coil pack under the battery ...
Posted on: 2025/5/4 4:53
