« 1 (2)
Re: Rare-er-er alloy diff carrier
Datsun Sunny 1000
B10 4.111 (37:9) sedan & coupe
B10 4.375 (35:8) van
B20 4.625 (37:8) truck
All use the same GEAR CARRIER part number 38310-18000
the bearing cap fit over studs and are secured with nuts
It also does not use the cheap crush sleeve that the cast iron H145 does, but instead has reusable shims
jpg  a.jpg (96.72 KB)
174_68328e0d0b72d.jpg 1200X856 px
jpg  c.jpg (106.47 KB)
174_68328e2dc4204.jpg 1200X856 px
jpg  d.jpg (131.58 KB)
174_68328e3482e9e.jpg 1200X856 px
jpg  e.jpg (155.50 KB)
174_68328e3971682.jpg 1200X856 px
jpg  37 X 9.jpg (166.50 KB)
174_68328e429eef0.jpg 1200X856 px
jpg  b.jpg (103.07 KB)
174_68328f3502e2c.jpg 1200X856 px
Posted on: 2025/5/25 4:28
Rare cast iron diff carrier
B110 used a cast iron differential carrier
Aside from the carrier case and bearing caps (with bolts), all the parts seem to be the same as the B10, except for the pinion crush sleeve. Datsun competition showed the gearsets interchanging
The case is part number 38310-G0400 COMP-CARRIER GEAR
G04 means designed for C20H 1970 Sunny Cab flatbed
jpg  H145 carrier, CWP, flange, crush sleeve.jpg (143.83 KB)
174_68329647d2b8e.jpg 1200X675 px
jpg  H145 carrier.jpg (192.06 KB)
174_6832968125cd9.jpg 1200X675 px
jpg  H145 crown wheel 145mm.jpg (69.57 KB)
174_683296888c946.jpg 912X640 px
jpg  H145 pinion markings G8608 A5.jpg (57.42 KB)
174_6832968fa023c.jpg 672X608 px
jpg  H145 crown wheel mounting face.jpg (57.14 KB)
174_68329695df119.jpg 640X640 px
jpg  cast iron.jpg (46.23 KB)
174_683296a39954f.jpg 1200X900 px
jpg  39-10 CN 47 5.jpg (164.68 KB)
174_683296a9b3e84.jpg 1198X898 px
jpg  H145.jpg (147.71 KB)
174_683296b690011.jpg 1198X898 px
Posted on: 2025/5/25 5:10
Re: Rare cast iron diff carrier
more pics
I notice the last one has an oil cooler line fitted. This one shows it in more detail
jpg  Pinion with bearing.jpg (56.99 KB)
174_6836936457970.jpg 900X675 px
jpg  pinion flange.jpg (36.94 KB)
174_6836936d76568.jpg 1152X352 px
jpg  NISSAN 37-9.jpg (44.22 KB)
174_6836938eadda2.jpg 900X675 px
jpg  gear set.jpg (62.92 KB)
174_683693b96d074.jpg 1200X900 px
jpg  gear set wtith crush sleeve and flange.jpg (58.99 KB)
174_683693c8946fe.jpg 624X656 px
jpg  H145 oil return line.jpg (49.16 KB)
174_683693ebae7d8.jpg 640X816 px
jpg  H145 gear carrier.jpg (53.09 KB)
174_683693f2450e3.jpg 704X528 px
jpg  oil return line fitted.jpg (102.51 KB)
174_6836a33d1491b.jpg 992X744 px
Posted on: 2025/5/28 5:42
Edited by ddgonzal on 2025/5/28 6:46:57
I suppose this why some racers use the alloy B10 diff instead of the B110 cast iron unit
9kg!
Never weighed a B110 actual diff, but it felt like 15kg
5.14 ratio. Seems like a rare ratio
jpg  9kg.jpg (148.93 KB)
174_6836aedd80d4c.jpg 900X880 px
jpg  Rally KB diff.jpg (126.90 KB)
174_6836aee635e04.jpg 928X656 px
jpg  LSD.jpg (120.94 KB)
174_6836af2901444.jpg 864X800 px
jpg  studs.jpg (118.82 KB)
174_6836af35b1f4d.jpg 900X960 px
jpg  pinion mesh.jpg (142.78 KB)
174_6836af467d8c8.jpg 1198X898 px
jpg  36.7.jpg (121.88 KB)
174_6836af54e629c.jpg 1198X898 px
jpg  left.jpg (186.73 KB)
174_6836af6433f72.jpg 1198X898 px
jpg  right.jpg (179.81 KB)
174_6836af70da7a3.jpg 1024X768 px
Posted on: 2025/5/28 7:36
From Las Vegas USA
I weighed both the all steel H145 axle and the H190 with aluminum diff housing and brake drums. The H190 was only 2 pounds heavier.
Posted on: 2025/5/28 19:25
Yikes, that's a severe penalty. Heavier than the first H145 (the alloy one), yet far weaker than the alloy H190
I wonder if a 1200 would ride better with the alloy diff and softer leaf springs? Too bad we never got a proper monoleaf spring review
Posted on: 2025/5/29 0:17
From Las Vegas USA
As mine is a race car I don't worry to much about ride quality.
Posted on: 2025/6/6 2:41
when I had the 13b in my 1000 the H145 with H150 centre took looks of abuse
more than I expected but had the H190 alloy diff ready but never needed it.
I revved the 13b engine to 9+k rpm and got pulled over for excessive noise
which led to a canary sticker for non engineered running gear.
Yet these little H145 are stronger than I expected them to be and so light
with the alloy centre that the H190 alloy seemed like double the weight.
Posted on: 2025/6/20 8:53
The Datsun 1000 alloy carrier is so light you can hold it on the tips of two fingers ... maybe. At 9kg probably not
The left bearing tower is stamped 'A'
jpg  H145 alumi.jpg (179.86 KB)
174_691fde925de9f.jpg 1200X1200 px
jpg  Right tower stamped 'B'.jpg (129.10 KB)
174_691fdebbe5a04.jpg 1200X1200 px
jpg  CWP.jpg (166.11 KB)
174_691fdf7a19187.jpg 1200X1200 px
jpg  Bottom strengthening bulge.jpg (111.83 KB)
174_691fdfae924a7.jpg 1200X1200 px
jpg  Bearing caps stud-mounted.jpg (121.87 KB)
174_691fe00d89a34.jpg 1200X1200 px
Posted on: 2025/11/21 3:45
« 1 (2)
