Fuel Pumps?
From Wanganui, New Zealand
I've started looking around for fuel pumps for my ca project, so far I've seen that quite a few people use the pump of a Vl for the EFI, what do you use for the pump from the fuel tank to the surge tank?
thanks.Cameron
Posted on: 2004/7/13 7:18
Re: Fuel Pumps?
From Melbourne,Australia
Hey mate im using a bosch motorsport one as my main pump with a L20 bluebird pump as my lift pump to the surge tank these operate at about 8psi which is enough to fill the tank depending on the size that you are using
Posted on: 2004/7/13 7:33
Re: Fuel Pumps?
From sydney
IM running a carter lift pump from fuel tank to surge tank and a 400-450 bosch fuel pump i got both these pumps for $330.
Cheers Luke
PS let me no if you want part numbers
Posted on: 2004/7/13 8:10
Re: Fuel Pumps?
From Sydney, Australia
For surge tank primer pumps, anything will do for most situations, I mounted my surge tank under the car and gravity through 3/8th tube (bigger than 1200 standard).
So any low pressure electric pump will do, the Bluebird pumps from the L20B equipped ones is what I'd recommend. $10 from the wreckers.
For the main EFI pump, The VL external pump is ok, but if they run at 12V all of the time, they will ALL overheat in summer in traffic. If you don't believe me, you will be cursing my name when it does happen to you. I had brand new ones and second hand ones behave exactly the same when the temperature got over 28degC. The fix involved using a 1200 ballast resistor, a relay and a switch on the dash.
For my new install, I've cut the side out of the 1200 tank, fitted a swirl pot in the base, and fitted a intank pump. The petrol keeps the pump cool.
Cheers,
Chris
Posted on: 2004/7/13 9:28
Re: Fuel Pumps?
From Newscastle, Australia
Id agree with chris, all you want is a pump which fills up the surge, then use a holley blue for both carb and injection with a regulator in line to ensure the right pressure is delivered to the fuel rail.
Posted on: 2004/7/13 10:23
Dont die wondering.....
Re: Fuel Pumps?
From Melbourne, Australia
anyone got a holley pump that they have figured how to make quiet???
mine is sooo damn noisey, i havent got the proper mounting grommets but did use big bits of foam on eaither side of the floor where i mounted it, i dont think that helped much
its mounted above/in front of the fuel tank on the underside of the boot floor
Posted on: 2004/7/13 12:15
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Fuel Pumps?
Sorry guys. I would never recommend Holley stuff. It's rubbish. The noise is not power, it is poor design.
For EFI use a Walbro or something from Bosch. (
What is a Holley Carburetor? A poorly controlled fuel leak.
EDIT: At least it is fuel pump related, and it really is my opinion on the Holley products.
It's like the people that preferred to use a Holley whatever double pumper in the 80s...The only pumping involved the speedshop owner with his pants down while the customer bent over.
Posted on: 2004/7/13 13:36
Re: Fuel Pumps?
When that happens, your engine is said to be suffering from "Holley Pox"
Posted on: 2004/7/13 13:49
Love your Datsun.
Treat it well.
Re: Fuel Pumps?
What model/year bluebird are they out of? For the efi pump, I was looking at buying Bosch 910 External fuel pump @ $267 NZ. Is this a good price?
Posted on: 2004/7/13 21:24
Re: Fuel Pumps?
I first thought they might be from the L20B equipped 910 Bluebirds, but they have a perfectly fine mechanical low pressure pump off the block.
So it's most likely from the early CA20 Bluebirds as the CA series don't have a mechanical pump attachment. Not the EFI ones, as they will only have an EFI pump, which is intank.
The external pump sounds ok. But the Walbro pumps off Ebay shipped from the USA are the cheapest at ~$170-$190. My brother used a 255L/hour intank version on an SR20DET and has no fuel problems at 190kW@rear wheels. The Walbros are smaller and quiet, but they keep the fuel pressure steady when it's required.
To give you an idea though, my old man is running a 2nd hand Mitsubishi Magna intank fuel pump, from the early 1990s V6 magnas, and he's got a reliable 160kW at the wheels in his SR20DET. Those pumps look wimpy, but do the job.
Basically with EFI pumps, size doesn't always matter.
Posted on: 2004/7/14 0:59
