« 1 (2)
Re: tyres rubbing?
From Brisbane
I was trying to keep it old skool if I can but at the moment it is off the road waiting for wheels after a stanza strut upgrade.
15" x 4" front really would be hard to find tyres for. It sounds pretty tuff with 295's on the back. I like the hot rod look.
Posted on: 2004/7/28 6:08
Re: tyres rubbing?
Quite a regular
From Adelaide
whta size would the origional 12" be cos mine just read R12
i want to run 14" or 15" if i can get them to fit
Posted on: 2004/7/28 6:09
Re: tyres rubbing?
The overalll diameter of the original 155-R12 tyre was nominally 554mm. The overall diameter of a 185x60x13 tyre is, guess what,...552mm. This is the important number to remember when buying front tyres. Rears can be bigger because they dont turn, they just rotate.
If you use larger diameter wheels, then the only way to achieve this diameter is with lower profile, higher priced, tyres.
The 185x60x13 is probably the most practical & most cost effective choice, but hey, if you got money to burn, then the sky's the limit.
Fitting the wrong size tyre means that you lose out on something, like turning circle, & body wear, but make the right choice & it's all benefit, & no real negatives. As for me, i dont want to lose any of the great features that the engineers designed into the car, & i will not be beating the crap out of it with a hammer either. Thats a butchers method of covering up bad work or bad choice.
P.S.
165x75x13 is nominally 578mm diameter
175x70x13 is nominally 576mm diameter
Posted on: 2004/7/28 15:06
Love your Datsun.
Treat it well.
Re: tyres rubbing?
From Brisbane, Narangba
I did a bit of panel beating on the fronts which worked perfectly now to curl the rear lip.
Posted on: 2004/7/29 7:27
Re: tyres rubbing?
From Castro Valley,CA USA
I've pulled the front tires forward a little ( more caster) and this gave me enough clearance for 185/60-13's.
Posted on: 2004/7/29 7:48
« 1 (2)
