1200 hubs on 1k
Quite a regular
From Adelaide
will 1200 hubs fit onto 1k stub axles?
i am pretty sure they do but want someone to confirm this
getting ahead of myself but if they do anyone in adelaide got a pair of hubs they don't need
Posted on: 2004/8/4 14:05
Re: 1200 hubs on 1k
Yes they do, but why would you want to?
Posted on: 2004/8/4 14:07
Love your Datsun.
Treat it well.
Re: 1200 hubs on 1k
Quite a regular
From Adelaide
i want them for a brake upgrade. was looking at the sigma caliper version?
your thoughts on this dodge man
oops would have to be coupe hubs though
Posted on: 2004/8/4 14:13
Re: 1200 hubs on 1k
From Sydney, Australia
Or Ute ones, or some optioned ones too Just not dodgy early model sedan ones.. Sedans are so lightweight, they just need flintstone brakes...
Chris
Posted on: 2004/8/4 14:18
Re: 1200 hubs on 1k
From Perth
They will go on
Same bearings
And the hub will hold the little solid disc
Then you need to make a bracket to suit a caliper
Or.....buy a kit off me......lol
Posted on: 2004/8/4 14:29
Re: 1200 hubs on 1k
Don't bother dickin' around with it as many [including me] have had a go at this problem before without a lot of success.
I just bit the bullet & contacted dattoman_1000. He has a kit which includes new billet hubs that does the trick nicely.
You can get just the hubs & the caliper mounting plate, & source all the other parts seperately yourself from new &/or used parts sources.
As for me, i just accepted his offer for his very competitively priced "deluxe" version of the kit which incluides
New Caliper mounting plate
New billet hubs
Caliper overhaul kits & new pads
New ventilated rotors [discs] Mmmmm ventilated rotors.
New hoses
New Datsun 1200 coupe rear wheel cylinders. [smaller bore]
New Sunny master cylinder [bigger bore]
New custom pushrod for the pedal to m/cylinder link.
All fasteners [new]
To this you need to add some pre loved calipers, or new ones if you have the cash, & the whole thing fits under a 13" wheel.
This is a system that he developed about 10 years ago for his 1000 coupe & he is only now making available the "production" version of it. It is not cheap, but there is no way i could do the same for less, so i guess it really is cheap. Actually, i thought it was a bargain.
By buying the main [custom made] components & sourcing used components, costs could be reduced, but it involves a lot of running around, & that takes time that i do not have.
It's a true bolt on, with no drilling, cutting or welding required. That makes it the kind of engineering that i like.
Drop him a line & he will be glad to help you out.
Posted on: 2004/8/4 14:33
Love your Datsun.
Treat it well.
Re: 1200 hubs on 1k
From Perth
And I will weigh it all tomorrow and give you your final special price. Inc freight.
Posted on: 2004/8/4 14:41
Re: 1200 hubs on 1k
Thanks Neil, i'm looking foward to getting it home.
I like to deal with people that use the product that they produce & since you have been using this system for so long, i guess it must work OK.
If it's good enough for you, then it will be good for me too.
Thanks again.
Posted on: 2004/8/4 14:46
Love your Datsun.
Treat it well.
Re: 1200 hubs on 1k
From Perth
Kit will be despatched via Aust Post on Monday
Thanks again
Next ?
Posted on: 2004/8/6 12:43
Re: 1200 hubs on 1k
Thanks, i will be hanging out fot it.
Ventilated discs as a complete, or build it up yourself kit,... let me tell you, i have been waiting 20 years for something like this.
I ran drums on my 1000 sedan the whole time & while they worked well enough for what they were, they are not really up to the task of "sporty" driving, particularly down a mountain pass, & we have a few of those around here.
Thanks again, & i hope that other 1000 owners take advantage of your services. [mad if they don't]
Chris
Posted on: 2004/8/7 6:05
Love your Datsun.
Treat it well.
