« 1 2 (3)
Re: Stock gearbox and diff not that weak
From SA the place to boost
what you guys say is all go but what about when i get my ceramic brass button puck clutch, that you cant ride at all what do you suggest
Posted on: 2004/8/6 12:53
Nobody is suggesting that you "ride" the clutch, just try not to dump a heavy shock load on the driveline, & "use" the clutch instead of abusing it. A firm takeoff rather than trying to wheelstand it will pay dividends.
Posted on: 2004/8/6 14:42
Love your Datsun.
Treat it well.
I suggest that if you need that, then you will also need everything after it stronger also. Plus you might want to invest in a box of ear plugs, if its a daily driver you will soon get sick of the squeal of the clutch.
Posted on: 2004/8/7 0:49
squeal of the clutch???? why have i never heard this in my other cars or any of my friends cars?
it will have an RB20DET 5 speed and a Series 3 welded diff so im hoping it will be strong enough
Posted on: 2004/8/8 9:57
Stanza L20 Turbo
Bluebird Series 1 FJ20ET
Bluebird Series 3 TRX CA18DET
From sydney
You can ride a brass button clutch
Posted on: 2004/8/8 10:38
From Millgrove Vic OZ
One thing that is important noise wise is having a sprung centre to remove torsional vibration from the shaft and to ease shock loads on the clutch plate.
Clutch plates are available with upgraded spring centres and are much nicer than listening to drive line noises that sound like your gearbox or diff is breaking up.
Posted on: 2004/8/8 13:26
Cheers Feral
From Perth Austarlia
by locking the diff you are creating a weak point!!!!!!!
If you kept an open diff...excess horspower would turn into smoke. With a locked diff u have more traction....So try and imagine what is happening inside the diff housing...
Posted on: 2004/8/9 10:46
« 1 2 (3)
