Re: tacho wireing in late model 1200 ute
Without being cheekyQuote:
Please if you don't understand electronics. Please do some reading before continuing with this craziness.
Please do
You can't "burn out" the 1200 tacho.
I beg to differ. A 1200 tacho requires 3 wires to operate. Earth, Ignition 12V and Inductive loop.
Now the 12v ign supply terminal is clearly marked on the tacho with a ( + ) symbol, easy
Earth terminal clearly has a metal tab that goes to the housing. ( If one understands electrical principals it is clearly easily recognisable)
Inductive loop terminal has a piece of plastic with a hole through its centre. it has a metal strap over this plastic which has a stud and nut on it just like the other 2 terminals.
One might be led to assume that if an unknowing installer was to connect ignition positive to this terminal, one could actually burn the tacho. Who is to know how one has connected their tacho if they already show signs of missundestanding its instalation?
You've just short circuited the wire you installed. Great for melting wires...
I do belive there is no way john could of melted wires with his description of instalation. For example, if wire runs from A to B and finishes at C ( A = power supply eg, Ign 12v. B = load eg, coil positive. C = earth eg, coil negative.) We would have a complete circuit.
If one runs another wire in parallel from A to B whether it is looped through an inductive tacho or not, it would make no difference.
But if someone was to run a wire in parallel from A straight to C whether through an inductive tacho or not, one would soon notice melting wires upon trying to turn over the engine. This would result in a burnt ignition module ( for elec ign ) or melted points and wire ( for points ign)
Though I better clear up the misconceptions.
Cheers Steve
Posted on: 2004/8/7 16:16
Subject Poster Date
     tacho wireing in late model 1200 ute john_13961 2004/8/4 12:12
       Re: tacho wireing in late model 1200 ute phunkdoktaspok 2004/8/4 12:29
         Re: tacho wireing in late model 1200 ute john_13961 2004/8/4 12:41
           Re: tacho wireing in late model 1200 ute phunkdoktaspok 2004/8/6 8:48
             Re: tacho wireing in late model 1200 ute ISL33P 2004/8/6 21:23
               Re: tacho wireing in late model 1200 ute john_13961 2004/8/7 0:10
                 Re: tacho wireing in late model 1200 ute john_13961 2004/8/7 0:13
                   Re: tacho wireing in late model 1200 ute phunkdoktaspok 2004/8/7 0:32
                     Re: tacho wireing in late model 1200 ute john_13961 2004/8/7 9:07
                       Re: tacho wireing in late model 1200 ute phunkdoktaspok 2004/8/7 13:02
                       Re: tacho wireing in late model 1200 ute dattodude 2004/8/7 15:28
                         Re: tacho wireing in late model 1200 ute phunkdoktaspok 2004/8/7 16:16
                           Re: tacho wireing in late model 1200 ute john_13961 2004/8/7 22:18
                             Re: tacho wireing in late model 1200 ute john_13961 2004/8/7 23:18
                               Re: tacho wireing in late model 1200 ute 1956 2004/8/9 1:55
                                 Re: tacho wireing in late model 1200 ute john_13961 2004/8/9 4:03
                                   Re: tacho wireing in late model 1200 ute 1956 2004/8/9 4:25
                                     Re: tacho wireing in late model 1200 ute john_13961 2004/8/9 7:44
                                       Re: tacho wireing in late model 1200 ute Bute_Datto_Ute 2004/8/9 8:13
                                         Re: tacho wireing in late model 1200 ute john_13961 2004/8/9 8:48
                                         Re: tacho wireing in late model 1200 ute dattodude 2004/8/9 9:09
