« 1 (2) 3 »
Re: hey, from someone new
From south australia
ah i wondred why my right side engine mount looked different i must have a 120y mottor in mine
Posted on: 2004/9/1 8:57
ok i have checked and now i know my motor is out of somthing ather than a 1200
now how do i tell iff its a a1200 or an a 1400
Posted on: 2004/9/1 9:47
left hand side lookin into the bay, behind ur distrubutor, there will be a little flat pad, inprinted on it it will say either A12 A14 or A15... unless u have an A12GX or an A12A or A13 which is unlikley.
Posted on: 2004/9/1 9:57
78 model datsun 1200 ute. A15 twin webbers, dogleg 5speed.
Jk Rubicon unlimited, 58 CJ3B Willys
its just a humble lill a12
is the fuel consumption much greater in an a14--15 much greater than the a12
Posted on: 2004/9/1 14:15
From Invercargill, New Zealand
The A12 is the most economical but the extra torque of the A14 and A15 means you don't have to wring them so hard to get up to legal speed. You really will not notice the change in consumption.
Posted on: 2004/9/1 23:17
sold me so what other cars can i find the a14 or 15 in so its easyer for me to find one i am guessing the sunny would i be right oh by the way im in australia
Posted on: 2004/9/2 9:17
Early model N10 Pulsars and Sunny's are your best bet. A15's come up reasonably regularly on here as people do CA18DET conversions etc.
Posted on: 2004/9/2 9:26
so theres no major drama using a fron wheel drive engine from the pulsar
Posted on: 2004/9/2 9:33
Not really major stuff. You'll need mounts and a sump but your A12 sump should fit (someone on here can clarify that). Also the N10 A14 uses a thermo fan so you'll have to bolt your A12 fan on and use your A12 air cleaner hat. Oh and change the A14 thermostat housing with your A12. I think that's it.
Posted on: 2004/9/2 9:45
well as i allready have a 120why motor in mine the engine mounts should be the same is this true ?
Posted on: 2004/9/2 13:57
« 1 (2) 3 »
