« 1 (2) 3 »
Re: SR20 quad throttlebodies!
From Little Rock, AR
The Greddy intake sits up higher, the plenum is more raised up than the low hanging stock SR20 intake. Keep in mind however that the Greddy intake is set up for a different style throttle body than the stock S13 one. I think the S14 throttle body bolts onto it??? Anyway I had to have my Greddy intake chopped down in front cause it comes forward a lot more than the stock intake does. At the same time I had a throttle body plate for the 90mm Q45 throttle body welded to the shortened intake. I've heard these things have a little bit of a flat spot off idle simply because there's soo much more of a volume of air going through them! I'll get pictures up when it comes back in the mail. The Greddy intakes use the stock SR20 style injectors and fuel rail. If you want top feed style injectors you'd have to get a different fuel rail. There really isn't any need for all that, cause stock style injectors can be had in all sizes. My bro is pushing 400 rwhp with a GT40R on his 180SX and not having problems leaning out with 850cc injectors, 255 lph fuel pump, Nismo regulator, and stock fuel rail.
Posted on: 2004/9/3 11:19
Not too shy to talk
From townsville
easiest way to run quads on the street is through a plenum. better vacuum signal and you only need one filter. doesn't look or sound as good but . quads are good for top end power and flow good for high revs. long runner single throttle bodies better torque. best bet is quads with a turbo then u got the best of both worlds
Posted on: 2004/9/3 11:45
From Sydney Australia
Plenum for this setup.
Hit the jackpot with feedback cheers everyone!
Those of you who run this Quad TB setup with only TPS, what computers are you running and could you please tell me and would you be able to run this setup on a street car? and also the height of the Quad TB's including and not including the ram tubes thanks.
I thought about the GTiR Quads ive never seen them though (anyone got pics) Idont know if the pattern is the same as the S13 and I thought they only came out in turbo forms and a Gtir turbo computer on a NA S13 I dont think will work but he who knows let me know if im wrong.
Cant wait to see your pics of the G ready intake let everyone know when there ready. The G-ready way seems to be the cheeper way to go and i already got a S14 TB and a range of side fed injectors ( i think the side fed injectors are better personally but i think the quad TB setup only uses top fed style injectors).
Can any one post a link for some info on where to get the Gready one?
That was a long post, thanks for caring!
Posted on: 2004/9/4 11:27
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
Tsillay and lemonhead you guys got pics i would love to see them. Cant wait for your replies!
Cant wait to unleash some NA SR power Hoping to get at least 9000 rpm redline by the time im finished! The authourities wont let me turbo it so i will just have to do everything else!!!
Posted on: 2004/9/4 11:37
Could you Use the quad throttle bodies and the plenum Standard computer and just put the standard air mass sensor at the enterance to the plenum and mount the TPS on the quad TB will thin work?
Posted on: 2004/9/4 11:48
Not too shy to talk
From townsville
tps sensor on the throttle shaft should be ok. try putting the map sensor in the plenum between 2 and 3 cause the signal might be more stable reading from the middle of all four cyls.
Posted on: 2004/9/5 11:23
From Brisbane
I'm running These throttle bodies, Haltech E6K ecu, 2 Litre Sigma injectors, Same ram tubes (cut to length) custom made alloy plenum with a single 75mm intake, intake has a cold air intake extention on it, Air temp sensor mounted at the biggining of air intake, Uni filter, Malpassi adjustable fuel pressure reg.
This is all mounted on a big bore motor with extensive (not expensive i did all of the machining myself) lightening and balancing of motor. This set up is tuneable enough for a rallycar and is far from a pig to drive around town.
Sorry i don't have digital camera to post any pics
Posted on: 2004/9/5 12:13
Cheers lemonhead for the info, heard those computers are pretty good!
Just wonderin if you could measure the height of the throttle bodies cause i want to see if they will clear my bonnet (just the height of the TB not the ram pods) thanks?
Also (lemmonhead) can you use side fed injectors on this setup?
Scrubber does the standard computer have a map sensor anyway? I just thought it used the TPS, air mass sensor and O2(exaust) sensor.
Posted on: 2004/9/5 13:33
From Wellington New Zealand
I use a link plus, it's a great setup for the money.
It runs 440cc VR4 injectors, I couldnt tell you what the pump is out of...
Check my profile for a link to some piccies..
The bosch TPS sensor bolts to the end of the throttle shaft...
Posted on: 2004/9/5 21:51
Not too shy to talk
From townsville
sorry got me wires crossed thought you were talking about after market ecu. no map sensor your right it has air flow meter.should be right to run as you said.
Posted on: 2004/9/5 23:51
« 1 (2) 3 »
