« 1 (2)
Re: Panhard Rod / Watts Linkage
From Taupo New Zealand
I think I've got that book... it's called Advanced Race Car Suspension and I got it from Pace Publications in Wanganui.
Posted on: 2004/9/12 4:21
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
From Brisbane, Australia
dubvious benefit even in race car applications. There's an awful lot of very competitive leaf sprung race cars that do not incorporate any lateral link systems.
A Watts link will allow you to set or adjust roll centre height at the rear, but unless you really know what you're doing, you're probably just adding an unneccesary layer of complexity in setup. Same overall balance can be achieved by changing front roll centre to alter roll axis inclination.
For a road car, there is absolutely no need for a lateral linkage.
Posted on: 2004/9/12 5:50
Not too shy to talk
From New Zealand, Wtgn
Hey Guys,
Thanks for the tremendous feedback on this subject. Obviously a few different ideas of what's do
Posted on: 2004/9/12 6:19
Gotta Scratch.........
Not too shy to talk
Posted on: 2004/9/12 6:23
The purpose of Watts linkage or Panhard Rods is to prevent lateral movement in the back axle. It is a definite requirement when coil-overs are used.
What you've got to look at is how much suspension movement you are going to have. If it is small, say 25mm down and 50mm up, then Panhard rod is the way to go. For suspension travels more than that, and especially on heavier vehicles, Watts Linkage is superior.
Like most other things, the compromise is what you have to look at.
To summarise, I reckon that the score is as follows:-
Panhard Rod. Advantages--- Light, minimum unsprung weight addition, simple to make and fit, simple to adjust rear roll centre by altering pick up points. Easy to fit.
Disadvantages---Corners better one way than the other, especially when suspension travel is bigger.
Watts Linkage. Advantages---Back axle moves vertically up and down rather than an arc with radius equal to the length or the Panhard rod, so mudguard(=fender for Dave Gonzales) and body tyre clearance is minimised. Very strong.
Disadvantage--Higher increase in unsprung weight. More complicated. Harder to fit.
Conclusion:---If its a light car like a small Datto, Panhard rod is the way to go.
StewMcK
Posted on: 2004/9/12 10:13
« 1 (2)
