SR20DET tunnel clearence difference?
From EUPEN / BELGIUM
Hi firends,
Wonder where the differnce between an automatic and manuel transmission tunnel is?
I suppose the firewall opening is the same, and that the difference is more at the rear, in front of the shifter hole! Right?
Tia
Posted on: 2004/9/12 12:02
Belgian Roadster
SRL 311 69'
1200 SR20DET swap started
Re: SR20DET tunnel clearence difference?
From Melbourne, Australia
its ten times bigger all over
well maybe not ten, but the diffrence is very noticable even at the firewall
Posted on: 2004/9/12 12:14
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Mudgee NSW Australia
Im pretty sure the main difference is in the width looking at a auto tunnel its a lot wider from the front.
The height looks much the same Im using a S13 5 speed with a manual tunnel (in a coupe) it has heaps of clearance!!! the most important thing is to get the engine as low as possible for this to happen. If it sits high the large gearbox will hit.
Ill take some pics of mine soon and show you what I meen.
Posted on: 2004/9/12 12:51
If In doubt run more BOOST
Pictures of your S13 5 speed in the manuel tunnel would be great. BTW, what is the difference btween S13 and S14 5 spped gearbox?
Posted on: 2004/9/12 17:49
Belgian Roadster
SRL 311 69'
From Sydney, Australia
Pics would be good, how low have you actually mounted your engine to fit a S13 box in a man coupe without mods, I thought the very least you had to do was a bit of hammering for it to fit.
Posted on: 2004/9/12 18:27
I lied the tunnel did need mods around the rear of the tunnel where the shifter is I had to box it out. You will also have to remove the inside original gearbox mounting brakets. The engine does sit low 30mm lower than i had originally fitted it all. illgo up and take some pics tonight.
Posted on: 2004/9/13 10:31
As I said! in the rear, close to the shifter!
I'm going to cut out the tunnel of my spare 1200. I'm going to weld it in more backwards, so I will win some space.
For better understanding, imagine slidding the hole tunnel 15 cm to the rear, and fill up the space created between the firewall and the tunel with the spare tunnel.
Should be perfect fit. Anyway, I'm going to take pictures soon.
Posted on: 2004/9/13 11:43
Belgian Roadster
SRL 311 69'
Sorry about that I didnt read the question properly as usual !!!
I have now posted pictures in the mechanical -drivetrain section
Photos
Posted on: 2004/9/13 13:20
