« 1 (2)
Re: blew another head gasket!!!
From Canberra
what does it cost roughly to get a head/block/both shaved... I'm thinkin my headgasket is blown, there's milky oil coming out the crankcase breather now and it misses and runs like 5hit at anything above idle.
Posted on: 2004/9/14 8:38
From Taupo New Zealand
doesn't sound good mate!
to plane a head at a machine shop like ours would probably only cost $50 or so.
to get it done at an engine reconditioners would probably be a set price, and probably quite a bit more than $50. Generally they charge like wounded bulls.
Posted on: 2004/9/14 9:05
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
From Canberra
thanks nzdatman, i guess i don't have a choice... bugger
Posted on: 2004/9/14 9:20
From Canberra
OK I got a gasket kit ( $155 ) and started pulling the head off, but I cant get the inlet/exhaust manifolds off, it looks like they've been put on recently with stag paste. Any ideas on getting them off?
I thought maybe pour hot water over them?
-Tyrie
Posted on: 2004/9/16 4:27
From Invercargill, New Zealand
Leave the manifolds and carby on. Just pull it off together if you are only changing head gasket.
Posted on: 2004/9/16 4:44
From Canberra
I would leave them on, but the extractors are welded to the exhaust pipe.
Posted on: 2004/9/16 4:50
From Canberra
Ok call me an idiot but I was having a look at another set of extractors today and realised that there are bolts on the underside too.
So i took them out and pulled the head off: and all seemed okay just the back cylinder was full of water...
Posted on: 2004/9/16 10:40
and that's OK with you?
Posted on: 2004/9/16 10:49
1970 1200 coupe A15
1978 B310 SR16VE
From Canberra
of course not, but at least i know the problem now
Posted on: 2004/9/16 10:56
« 1 (2)
