« 1 (2)
Re: toyota 5-speed
Come on some 1 must know?
Posted on: 2004/9/13 12:25
78 model datsun 1200 ute. A15 twin webbers, dogleg 5speed.
Jk Rubicon unlimited, 58 CJ3B Willys
Re: toyota 5-speed
From Canberra
Im getting a t50 for $220 next week, do I need the tail-shaft also?
Posted on: 2004/9/18 3:49
Re: toyota 5-speed
From Christchurch NZ
woodydat wrote:
Hey, i went for a ride out the bush yesty and found a Toyota corona, It has a 5 speed box in it, and a 2litre motor,
Is the Gearbox Any good in it?
is it like a T series box etc.. is it worth getting?
Tie a rope around it and roll it over, then see what like it is. I scored a toyota crown for free, and it had the big toyota 5spd in it.( This will be going in my Charger) Chances are the corona box will be ok.
Posted on: 2004/9/18 6:01
Forced Induction!
Re: toyota 5-speed
So how do i tell if its a good box? like if it is a box worth ne thin.. i'll go out there through the week with some mates and turn it over and see what it's like.
Posted on: 2004/9/18 6:38
Re: toyota 5-speed
From Canberra
so what other bits do I need out of the celica?
do I need the tail shaft and crossmember?
Woody, just take the whole car home and pull it appart, good practice and you might find other useful stuff
Posted on: 2004/9/19 1:40
Re: toyota 5-speed
From Perth
You would want to take
Shifter.....derr.....but some people forget such things
Tailshaft....to get the front yolk off
Speedo cable if its there.....I think the datto one fits but take it just in case
Gearbox mount is probably no good to you
Posted on: 2004/9/19 7:01
Re: toyota 5-speed
From Canberra
so is the datto tailshaft modified at the gearbox end and used or is the toyota tailshaft modified at the diff end and used?
Posted on: 2004/9/19 7:42
« 1 (2)
