« 1 2 (3)
Re: electric supercharger
From Sydney Australia
I think you should get one of these
haha
seen it in an add to the left
Posted on: 2004/9/19 12:31
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
From Canberra, Australia
looks like a load of horse s*@t... in fact it looks allot like my computer fan
Posted on: 2004/9/19 14:03
From Perth WA
1200 rally car, of course i will keep playing with the thing for experimentation sake. thats how i pulled a V8 beater out of a 3 litre n/a V6 in the first place.
And i did not test the acceleration by a mate with a stopwatch, of course times would not be that consistent if i did that. but i did have a mate making contact with jump leads when i blew it up on the weekend.
btw the device runs straight out of battery not alternator, thats why i had it drawing 80 amp with an old battery down on voltage a bit. But i know it cant really handle 120amp like they claim because i replaced the 50 amp fuses and holders with big dyna-links with 60 amp fuses to do the 24V test.
this was done with another battery outside the car, a jumper lead between, and holding revs at 5000 steady and then making contact with 24V. The idea is the revs should have rise a bit under any boost, but that didnt happen.
and its only meant to run for 15 secs, so battery can recharge.
anyway i burnt out the motors in under 15 secs, so thats the end of that, it didnt blow the two 60 amp fuses i put in so i know its bullshit that it draws 120 amp.
fair enuf u built a TT for 1200$, well done, but u cant do that on a modern efi car, just the injectors or turbo or IC or the ECU all cost about that much EACH even if plumbing, wiring and evrything else done youirself.
Posted on: 2004/9/20 7:32
From Newscastle, Australia
Why couldnt you do an inexpensive turbo mod to a modern car? Or even a Magna.
If I had a magne (errr shudder) I would put a stage 2 NOS kit on the thing and do some destructive testing on it. And surely the auto would be able to handle 20 more kw...if not they are worse than I thought!
Posted on: 2004/9/20 7:56
Dont die wondering.....
yes, some popular cars can be turbo'd without changing the ECU, e.g. Ford. Just get bigger induction and injector ...
Posted on: 2004/9/20 7:58
From Perth WA
guys adding NOS is not turbocharging.
and i didnt say the trans cant handle an extra 20 kw over stock. It already handling an extra 50 kw (about an A series worth) It just cant quite handle 2 extra A series worth of power taking it over 220Kw well into the bang zone!
Posted on: 2004/9/20 9:56
« 1 2 (3)
