(1) 2 3 »
Another problem :(
Again my sunny is in need of help!!
I am driving to school the smorning when i notice my heat gauge gradually moving higher, pull over notice that my NEW top radiator hose is quite kinked in the middle...Get to skool shave some of it off, thought was fixed.. NO
Driving HOME gauge getting higher and my engine is considerably hot and my radiator is bloody steaming, WAT IS WRONG!!! I just got a new (2nd hand) 323 '77 radiator but its fine what else could be the prob?? Water pump?? Gasket??
Anyone care to help me!!
Dave
Posted on: 2004/9/21 8:08
Re: Another problem :(
From sutho shire
dude sounds like u have a blown headgasket, whip the head of it and get it machined up new gasket kit and should be sweet, if your radiator hose is kinked it could also be your themostat, my adive is 2 get head machined new gasket new thermostat, then u will have no worrys,
Posted on: 2004/9/21 8:17
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
Hmm twas thinkn that coz i am getting bubbles coming out of my radiator when flowing.....
But surley could it just be like thermostat, water pump or maybe blocked lines etc??
Dave
Posted on: 2004/9/21 8:32
From sutho shire, NSW, AUS
nah dude, bubbles in the radiator sounds to me like a head gasket.
Posted on: 2004/9/21 9:49
From sydney
Have you got milky looking oil under the oil filler cap?
If you do take the head off I would check it for trueness with a steel rule before i bothered to get it shaved,dont waste your money if it isnt out of whack.
Posted on: 2004/9/21 10:18
From Canberra
had mine shaved today, looked pretty good under the straight edge, but there was a small channel goin from the water jacket to the back cylinder... I'd say get it shaved anyway.
Posted on: 2004/9/21 10:28
From South Africa
Get a compression test done before opening up head.
Posted on: 2004/9/21 10:32
Life's a bitch, so f...k it.
From Wamboin near ACT(canberra)
hey maete, im havin the exact same problems. i have o idea wat 2 do or check as i have checked everythin!!!. Apparently my hhead gasket and head is all fine, my thermostat is opening, all of the cooling stuff is working!!. The a15 radiator with a thermofan and engine fan should be good enough 2 cool an a15 in 22 degree temperatures shouldnt it???. Im stumped as 2 what 2 do?
Posted on: 2004/9/21 12:25
hey maete, im havin the exact same problems. i have no idea wat 2 do or check as i have checked everythin!!!. Apparently my head gasket and head is all fine, my thermostat is opening, all of the cooling stuff is working!!. The a15 radiator with a thermofan and engine fan should be good enough 2 cool an a15 in 22 degree temperatures shouldnt it???. Im stumped as 2 what 2 do?
no i dont thats the thing its perfectly blacky normal!! :(
I duno wat is wrong, i have cheked thermostat not too good but i took it off to see if that would cool it down, and guess wat yup u guessed right its still friggen hot!
The only thing i can think of now is that my new (2nd hand) radiator is shaggeed or my cars filled up with alot of ####e..
and my superstsious thinking of a blown head gasket is no longer as the bubbles are just 'lil iddibiity ones that only happen when i crank her up from the hoses most likley...
I reallllllllllllly need some answers...
dave
Posted on: 2004/9/21 12:38
(1) 2 3 »
