Browsing this Thread:
1 Anonymous Users
sputtering.....Why |
i have a L20B everything stock except headers,and a single 45 weber.the guy i got the engine from said he jeted the weber.but i don't thing he knew what he was doing.from idle(1000rpm)to (2500rpm) the throtle is good but if i stomp on it it sputters.and somtimes i'll hold the throtle to the floor and the engine wants to die.even on the road. if i want to pass half-throtle it sputters.i need help.what could be the reason for that.maybe i need work done to the head??or maybe somthing else??ingnition??thanks for your help
Posted on: 2004/10/19 7:23
Re: sputtering.....Why |
From sydney
Does it die if you feed it gradually or only if you stomp on it?
Posted on: 2004/10/19 12:26
From Sydney, Australia
Webers have accelerator pump jets, drill them out a very tiny bit (with an appropriate number drill), but it could be the broad difference between idle and secondary jetting. Get a weber expert involved, or borrow the weber tuning book from the local library (If available).
Posted on: 2004/10/19 12:37
the engine wants to die when i stomp on it.what do you think?
Posted on: 2004/10/19 18:42
From Canberra
My dad had the same problem in his H20 when i gave him some spark plugs, they were obviously the wrong ones so he put new ones in and it ran fine
Posted on: 2004/10/19 21:12
Registered Users Contentmaster Usermaster
Could be fuel OR spark. Check the spark plug wires with an ohm-meter.
- Replace those that are bad - look for and fix all the vacuum leaks
don't open the carb up until you check the external possibilities. Find out who's the local carb/tuneup guru and buy him a case of beer while he helps you ...
Posted on: 2004/10/20 6:36
Quite a regular
From Blue Mountains, NSW
by sputtering do u mean missing. as in the whole car is jerking and shaking cos mine misses when i keep my accelerator at one point (like at a constant speed). It isnt a pleasure to dirve like that i can tell u. I have checked plugs, dizzy, conductivity..everything. I know how u feel mate. Hope u fix ur problem!
Posted on: 2004/10/22 2:12
So Many Pedestrians, So little time!
in any gear if i pass half throttle then it misses/sputter.
when in nuetral if i rev it slowly its o.k. but when i want an instant rev it sputters. ONLY IF I PASS 3000 RPM AND THEN STOMP ON IT I GET INSTANT REV.BUT FROM IDLE IT SPUTTERS IF YOU REV IT FAST.HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! LIST ALL POSSIBLE PROBLEMS AND I'LL ELIMINATE.
Posted on: 2004/10/22 20:06
I doubt if any of us know "all possible problem" that could cause this. However, any Datsun 620 repair book should list the most likely causes in the troubleshooting section. I suggest checking one out from the library, or getting one (Chilton's, Nissan, Clymer's, Motor, etc) from eBay or http://www.amazon.com
Posted on: 2004/10/23 17:11
From Maryborough, QLD, OZ
This seems to be a bit of a common problem doesn't it? It happens to me to.....going around a corner in 2nd, press the accelerator gradually = no worries. Stomp on it ( and not neccessarily to the floor either) and the whole car jidders and stutters for a bit then off it goes.
When someone figures out what causes their prob, be it spark, carby or gremlins living in the glove box, let us know!!
Cheers
Posted on: 2004/10/24 2:41
