guys that have used the blow through setup!!
From durban, south africa
hey guys could those of you that have done a blow through setup give me some tips/pointers in the right direction. What did you do for a turbo manifold?
could i use a diesel turbo with this setup or should i stay with a petrol?
what did you do with the motor? cam, ignition, head and compression?
i have many more questions let's see how this post turns out
cheers guys
nicholas
Posted on: 2004/11/10 5:05
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
Re: guys that have used the blow through setup!!
From Christchurch, New Zealand
Should stay with the petrol turbo due to the difference in seals.
Posted on: 2004/11/11 9:36
1972 Datsun 1200 Coupe
Rosso Corsa Red
14" Watanabes
Twin 1.5" SUs to go on
Extractors w/ 2" exhaust and muffler
Sony Xplod Sounds featuring Active Black Panel, 4 Channel Amp, 4 way 6x9s & 12" Sub
From Melbourne, Australia
ask more specific questions, they are easier to answer
im using diesel turbos, theres no problem with that in a blow through setup
made my own exhaust manifold
check out my www below for a description of my setup exactly, under project cars
only mod to motor is the dizzy
it has been modified to have boost retard instead of vacuum advance, and has be regraphed and weighted
compressiona dn the rest is stock
i have a mild NA cam in it also
Posted on: 2004/11/11 12:41
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
