Blown A15
Hey guys i am trying to source a 4agze supercharger to fit onto my a15 what will i need to do to get it running. I already have twin webbers what will i have to do internally I am looking at getting things lightend and balanced anyway help please
Posted on: 2004/11/18 2:54
Re: Blown A15
From Christchurch NZ
You really should lower the compression ratio. The eastest way to do this on an A15 is to machine the dish in the piston so that it is centered, rather than ecentric. This will not affect the piston crown thickness, and will still leave a squish ring on the piston.
You will need a pulley to go on the crankshaft.
Posted on: 2004/11/18 3:42
Forced Induction!
Re: Blown A15
I dont really understand what do you mean by make it centred rather than eccentric
Posted on: 2004/11/18 4:16
Re: Blown A15
From Brisbane, Australia
Take the head off and look at the top of the pistons. The A15 pistons have a "beefy" top ring land. This makes them a great contender in the "livability" stakes when forced induction is involved.
Posted on: 2004/11/18 4:21
Re: Blown A15
From campbelltown (sydney) australia
like this
Posted on: 2004/11/18 5:17
Re: Blown A15
so the hollow machined into the top is how much bigger than standard
Posted on: 2004/11/18 6:42
Re: Blown A15
From stock, the dish on an a15 is offset to one side. Just machine out the part which is off centre.
Then get your head skimmed just enough to make it flat, so as to not raise the comp.
Posted on: 2004/11/19 3:25
Forced Induction!
