Anyone need an "J" series head ?
I have been told it is an "J" series head. I found it attached to an MGB engine. It bolts up to the MG engine but the combustion chambers and vavles are undersized for the 1798 BMC motor. This will go cheaply or to the dump.
Posted on: 2005/2/12 23:23
Re: Anyone need an "J" series head ?
heres a pic. If you want to buy it I will get it magnafluxed first.
Posted on: 2005/2/13 1:26
From Sydney Australia
photo no work
Posted on: 2005/2/13 2:06
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
This Link Should Work
Edit: Guess Not
But if you cut and past the URL below it will
http://www.members.tripod.com/andys_78mgb/datsunhead.JPG
Posted on: 2005/2/13 2:17
3 exhaust 2 inlet ??? looks strange
Posted on: 2005/2/13 2:29
From Okinawa, Japan
This engine was available, at least here in Japan, in the 520,521,620, and I'm pretty sure some 720 datsun pickups. They look similar to the A series with obviously different exhaust/intake and water neck setups and a cast iron head.
Posted on: 2005/2/13 2:48
