strut changes
From Albany creek Brisbane
I've read alot and heard alot about what struts and front end parts are needed if I want to put 15" trx wheels on my coupe.I just want to know is stanza struts and brakes fit can I put my 1200 coupe lowered king springs in and what front end parts will be needed. The only thing in tech info is 180b change over thanks
P.S. has anyone heard where u can get a bolt on stud changer to go from 114.7mm to 100.mm stud pattern for later model wheels
Posted on: 2005/2/15 8:46
Re: strut changes
stanza struts fit ... 1200 springs fit stanza struts ... you need to use the 1200 strut tops for it to fit in the strut tower though ...if you want to go the whole hog get stanza struts, steering arms, ball joints, control arms, sway bar link bolts ... also get 120y castor/radius rods and sway bar ... if this doesn't answer what you want to know try a search in the thing on the left for more info .... try wheel places for the conversion plates, don't know if they make them but i'm sure they could tell you ... unless someoe else on here knows
Posted on: 2005/2/15 9:57
Re: strut changes
From campbelltown (sydney) australia
yo boofhead or anyone else, does the 1200 spring go into sunny strut? and wat other mods are needed to the sunny strut other than bigger holes in the strut tower?????
Posted on: 2005/2/15 11:56
* caution, sunglasses must be worn to view my ca18det *
Re: strut changes
From Brisbane Australia
when u buy the sunny struts make sure u get the lower control arms because they have bigger ball joints , drill out the top holes and ya done tooooo easy,and yes same springs as standard only a little heaver
Posted on: 2005/2/15 22:02
Re: strut changes
if they're the same diametre spring coil and your orig 1200 bearing and top plates are ok, just use them to save drilling
Posted on: 2005/2/16 5:03
Re: strut changes
this great thanks can u still put the TRX rim on the sunny struts without spacers
Posted on: 2005/2/16 10:35
Re: strut changes
Also, will trx rims fit on sunny struts, drums etc with out spacers and no guard rubbidge??
Thinking of investing! Anyone with some trx rims in tassie they want to sell me??!!
Cheers
Dave
Posted on: 2005/2/16 11:04
Re: strut changes
no idea about trx rims .... sorry
Posted on: 2005/2/16 22:23
Re: strut changes
From Launceston,Tasmania,Aus
I know of about twelve rims being sold in sets,painted white.
$150.00 a set...
(in Launceston too)
Posted on: 2005/2/17 1:49
Proud member of " The Tasmanian Datsun Owners Group"......
