Aluminium Flywheel
From Perth Austarlia
Does anybody know where I can get some cheap aluminium to make a flywheel?
I live in WA? Please don't say scrap metal place (unless u know of one which gets large pieces) Buying new, seems like it would be quite expenssive??
Posted on: 2005/3/16 3:21
Re: Aluminium Flywheel
Don't know what companies you have over there but somone like Capral Aluminium should have what you are looking for.
You will need to get the right grade of aluminium also to suit what you are trying to use it for.
Not over expensive, the machine work is usually the expensive part of an alloy flywheel.
Posted on: 2005/3/16 4:47
From Taupo New Zealand
Aluminium is pretty bloody expensive. In NZ it is anyway. Have you thought about making a steel one, it would be a lot cheaper.
Posted on: 2005/3/16 6:10
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
From Perth Western Australia
possibly head down to henderson, and ask one of the boat building companies there for a bit... seems to be no shortage of aluminium there
Posted on: 2005/3/16 6:14
From Perth
I got my alloy one made in Melbourne cause I couldn't find anyone competant to make me an alloy or steel one here in Perth
But yes once you find out the grade you should be using start the ring around.
Posted on: 2005/3/16 12:16
From Millgrove Vic OZ
Cheap grades of aluminium + flywheel in the one sentence= big banga boom!!!!
The right grades are not cheap.
Posted on: 2005/3/19 22:16
Cheers Feral
Like Feral says, wrong grade of alloy & you got problems.
So what IS the right minimum grade? I don't know,... or care, as i'm not making a flywheel, but you would be wise to find out, & care a lot, as the wrong chioce could equal one very unhappy Datsun driver.
Will you be machining it yourself, or paying someone? How do you propose to securely fit the friction surface insert?
Posted on: 2005/3/20 12:26
Love your Datsun.
Treat it well.
From Perth
I don't know the actual grade of material
But this is what it looks like when finished
Posted on: 2005/3/21 11:14
quite a bit of work in one of those...
unless you're a competent machinist you'll have to pay ####loads to get one made, and if you were a competent machinist you would more than likely know where to buy the material
If you are paying someone to do the job, why not just let them worry about where to get it and the correct alloy to use? They will probably put on their margin but they will buy it cheaper than you could anyway, so in the long run probably not much difference in price but less hassle for you.
Posted on: 2005/3/21 11:37
1970 1200 coupe A15
1978 B310 SR16VE
