Valve Springs
From Wanganui, New Zealand
My ute has gone and broken another valve spring after only having back on the road from the last valve spring that broke!.The springs that are on the head at the moment are just single springs that have been shimmed up to about 90lb. I'm just wondering what other valve springs other people use in their A series heads as this is the second time its happened so I'm trying to get engine rebuilders to get some decent springs.
Thanks
Posted on: 2005/3/16 20:01
Re: Valve Springs
From Ipswich,QLD
hi nz_datto... im going to be using crow cam springs which are available at crow cams cabelfield victoria these are used inthe 1 litre sprint cars over here most people ive spoken to have said these are a good spring and work well , these are also rated at 90 lb they cost me 82 aus dolars may be worth a try there also designed for the a12 and fit straight up with no problem .,..........cheers.......
Posted on: 2005/3/17 5:53
Re: Valve Springs
From Adelaide, South Australia
120fly is right i'd tell you to use crow cam springs.
the product number is 4220.
good luck
Posted on: 2005/3/17 6:32
Re: Valve Springs
From Ipswich,QLD
dont mean to be rude killer 1200 on my crow box it says 5038-8
heavy duty 4 cyl springs
batch no :PK04-11A
just incase you wanted to know what i was exactly running .........cheers
Posted on: 2005/3/17 6:42
Re: Valve Springs
From Christchurch NZ
Talk to kelford camtech, 03 3664514. www.Kelford.co.nz
They can sell you some competition springs, part numberCB4A02. Mine cost $123.75 includung.
That was in july "03 though.
Posted on: 2005/3/17 6:50
Forced Induction!
Re: Valve Springs
The ones i am telling him to use are double springs.
Re: Valve Springs
Ditto!!!!!!
Posted on: 2005/3/18 7:54
Forced Induction!
