Rogue wrote:
The Subaru Hitachi electronic dizzy (the one that a lot of people said was too hard a conversion and phunkdokta said was going to throw the press-fit bearing off !)is going extremely well.
Dude your a joke. When did anyone say it was to hard a conversion? You are the one who stated its so easy and an E15 dizzy is way more difficult.
And when did I say it will throw the bearing off? I know 100% I never said that because I know 100% a bearing cant be thrown off a shaft of which it can only come off one way and that shaft has to be removed from the housing before this bearing can be removed. From memory I said I dont belive the dizzy only has the bearing pressed in and the bearing not held in place by either a bearing plate or the shaft itself is shimmed so there is minimum end float posible at the gear end. The exact thing you said is nothing.
I still havent seen any pics of this so called dizzies bearing setup. I on the other hand posted pics of exactly what I was describing.
So get your #### straight an untill then keep my name out your mouth.
I am really happy for you that your engine is running, it sounds good. But what you describe of destroying 3rd gear, has nothing to do with power. It has to do with good compression.
Gave it a quick squirt in third (on and then off the throttle about 5500rpm)and broke a tooth off third cog.
Just like if you drop down a gear too early and compression lockup occurs - something has to giveway.
Bro I can joke on this forum with others even if to other not involved members it looks serious. But dont try and bigup yourself by trying to outdo others, cause thats sad and makes you a joke.
