help not boosting(reving)
From penrith,sydney,aus
now when i put it in the garage it was fine and now when i took it out went to rev 2nd out a bit and it didnt come on boost but the boost gauge was reading about 6 psi
just wondering if anyone had any suggestions
Posted on: 2005/3/23 7:21
Re: help not boosting
From penrith
where is the boost guage plumbed in at?
does the turbo still spool up at all?
Posted on: 2005/3/23 7:35
Re: help not boosting(reving)
its plumbed in on a vacuum pipe on the block somewhere i think
they turbo seems to be spooling and the wastegate is still opening so i dont know
i thought maybe something electrical maybe not enough spark or something
the car does this sometimes when it gets hot too but normally only in 2nd
now its doing it all the time so
its pretty weird
sorry guys its been a slow day
the problem is the car wont rev past about 4500 so the boost is reading on the gauge but hasnt got the revs to kick in
any suggestions on what is causing this
Posted on: 2005/3/23 7:45
From Melbourne, Australia
if the gauge reads 6psi then its making boost... (or the gauge is rooted)
do you normally run more boost than this?
doesnt make sense, if it says 6psi then theres 6psi boost, nuff said really
Posted on: 2005/3/23 8:44
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
if it wont run over 4500 then you probably have a fuel problem, but this is seperate to not making boost
what motor, whats the setup?
Posted on: 2005/3/23 8:46
1200 Coupe Rallycar
sorry its an a14 running on gas t3 turbo running new gas research
normally only run 6psi its like it wants to boost but it just wont rev enough
gauge is brand new autometre
i think it is making boost i just explained it wrong first time round sorry
Posted on: 2005/3/23 8:49
i had problems where it wouldnt rev past around 4500 also, it would also cough a lot if held on boost for a long period, cant rmember exactly what it was at the moment but im sure i wasnt getting enough fuel pressure
Posted on: 2005/3/23 9:04
1200 Coupe Rallycar
From Blue Mountains,Syd,Aus
so now its the turbo... have you got the overheating sorted out.I spoke to Brett he said to take it to the radiator place on Batt street.
Posted on: 2005/3/23 9:05
so it could be something to do with the gas mixer
mine also when i wasnt hitting boost or reving it starts stuttering a bit so i might just have to take it to my gasman
still not sure about the overheating next thing to check could be the timing
i got the radiator from a place in batt street as well
Posted on: 2005/3/23 9:13
From Northern NSW
i know with my old cordia if i ran less boost lets say 5psi the car just would not rev any more then that magic 4500rpm.......but as soon as i up the boost booooyaaaaaa see ya later revs striaght out imediatly ......so i know how u feel its a very very annoying problem but at this stage its hard to say what it is exactly .....but 6psi on a gauge is 6psi there is no two ways about it unless ofcourse the gauge is stuffed but a good way to tell this is that on idle it should run at -15 to -20 psi thats a good sign that ur gauage is workin
sorry no great ideas at the moment but im thinkin
Posted on: 2005/3/23 10:16
dato ute (see avatar)
a14 blowthrough turbo motor
Import Auto Parts
For all your jap performance parts and accessories
pm for availabilty and quotes
