« 1 (2)
Re: lifting out engine
From Dallas TX
Great info and suggestions. I like the pole idea. I may try that with a 4x4 and a couple of straps. I think I'll probably need a third person to bolt it into the engine stand. Maybe my wife can do that :)
MIchael
Posted on: 2005/4/28 15:11
From Canberra
I'd say the problem isnt the weight (me and my bro loaded and unloaded 3 a12s complete with flywheel, oil, manifolds etc on and off my ute no worries.) In my mind the problem would be having to lean into the engine bay to lift it (I see back injuries) so the pole and chain idea sounds good to me.
Posted on: 2005/4/28 23:32
From sydney
I have done it on my own in a Suzuki Lj80, and with a mate in a 1200 using a bar, and I reckon its a bastard of a job.
Find a tree or rig up a frame it just makes it so much easier.
But to answer your question yes you and a mate will be able to remove the A12.
Posted on: 2005/4/29 0:25
strong bit of wood, or steel and rope, two people lifting off the suspension struts and if possible a third to guide it over the radiator support panel.
Done it twice with1200rc but now have a block and tackle, takes longer but safer and more precise (unless you loose you balance and almost fall thorugh the wind screen.)
Or i use my mechanics hoist and engine crane..... takes 5mins max after all bolts and hoses etc disconeected
Posted on: 2005/4/29 14:21
From Okinawa, Japan
My buddy and I lifted a CA out of a silvia with the turbo and mani removed and all accessories removed with an exaust system and a chain. The car was on stands and we had ramps on either side to help us lift it high engouh. An A series has gotta be cake, but got a cherry picker available now and that was just a drift car so we weren't too careful.
Posted on: 2005/4/29 16:06
« 1 (2)
