« 1 (2)
Re: tranny plug
Freak is thinking the drain plug has a female head, Freak the drain plug in question has a male head.
Posted on: 2005/5/2 15:01
Re: tranny plug
From Melbourne, Australia
mperdue i think the only way now will be with vice grips, but even that will be fun
Posted on: 2005/5/3 3:33
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: tranny plug
From Melbourne, VIC
If the drain plug has a male head then the simplest way to loosen it would be to use a female half inch square drive ratchet. By lengthening the handle with a bit of pipe you will get greater leverage. No need to use hammers, vicegrips, chisels and other implements of destruction.
Posted on: 2005/5/3 4:49
Re: tranny plug
Obviously someone doesnt know the difference between male and female maybe its the tranny part that has you confuzed.
***Edit*** You did say female half inch ratchet. Never seen one but it would definately work.
Posted on: 2005/5/3 8:41
Re: tranny plug
From sydney australia
i know that a 14 mm open ender spanner fits,but i've also found a 17 mm ring spanner will fit.this helps in 2 ways (a) it's usually a longer spanner,so more leverage & (ii) it places the torque on all 4 corners of the plug & (3) you
can get another spanner on the end of the 17 mm for yet more leverage.oh,& a bit of heat into the transmission case will expand it enough to be a bit easier.
Posted on: 2005/5/4 12:40
Re: tranny plug
From Melbourne, VIC
Phunk,
Many years ago Sidchrome made female ratchets. They came with a square drive piece which fitted in the drive (female) hole. To reverse you simply changed the drive piece to the other side of the ratchet. A very handy tool to have in the kit, which after over 30 years is still complete.
At my age I'm positive I know the difference between male and female.
Posted on: 2005/5/4 13:09
Re: tranny plug
Yeah I did think there was one out there, just I never seen them. Only kind that comes to mind is and old scissor jack handle but that would have been about 10mm.
At my age I am positive I still have plenty to see
Posted on: 2005/5/4 13:42
Re: tranny plug
From Adelaide, Australia
I have a ratchet that is female 1/2 inch, the way it works is, it can only turn one way and it has a 1/2 inch square bit that sits in and you can push it through to be either on one side or the other, so that it will lock clockwise or anticlockwise etc. Or for your application here, you could take the bit out. You can borrow it if you want to ship it overseas.
ediot: i just your comment snowy, mine doesnt have a sidchrome stamp, maybe someone made them too, i dont have a box or any sockets, i found mine at a second hand store, does yours have a click? mine is just smooth with no noise.
Posted on: 2005/5/4 14:18
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: tranny plug
From Melbourne, VIC
Yeah. My ratchet has the Sidchrome brand and part number on the handle. The handle is slightly longer than a normal male ratchet, so you can apply a bit more leverage to it. It has a loud clicking sound when you turn it.
Cheers.
Posted on: 2005/5/5 0:19
« 1 (2)
