« 1 2 (3) 4 »
Re: Advice wanted from the experts
From Melbourne Vic
sounds very feasable. if you keep it simple the costs will stay down. the diff will hold up (just) from your ute, just need to upgrade the front brakes and the rest is the CA install. the standard computer is a much underated thing, definately stick with it if on a budget, if everything is done properly it'll start first time, no tune!
good luck mate
Posted on: 2005/5/2 10:30
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From penrith,sydney,aus
yeah i thought the diff will hold up for a while and the front brakes are already upgraded to skyline discs so all i should need is a booster and it should all be sweet
ill probally also use the cheap supra intercooler i already got at first to also save money on that
topdat if you also cut down on a few things like a cheaper alternative intercooler and also let the stock diff do some work that would cut your budget down almost 2000
just a thought
Posted on: 2005/5/2 10:39
From Adelaide, South Australia
Maddat are fine, its just the cost assosiated with a workshop that i don't like. and there would surely be a workshop in your area that could do just the same job as maddat. all the datsun "specialists" will tell you the other ones are crap. maddat, datsport, cm510, nissco.... really the only way to know who is right is by knowing yourself first. the $7000 quote would not be including a motor and gearbox etc, so it would be about ten grand and really you'd end up with a bare bones conversion.
But your wrong that price with engine, gearbox, tailshaft, clutch ,exhaust, mounts, wiring.
I don't know if thats with a diff and struts i'd say no.
Posted on: 2005/5/2 10:52
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
From Melbourne Vic
i'd be quite interested to see what that money gives you and what you would still need to get. i guess its not so bad then.
Posted on: 2005/5/2 11:18
From brisbane qld
give this no a go. ken rawley i think his name is he has done some nice dattos. 38144674
Posted on: 2005/5/2 14:02
From Bris-Vegas
His name is Kev Rowley, & yes he does some very nice datto work (he's working some magic on my 1200 ute)...........But, I think it's a bit much to go giving his number out on this site......... Can you please edit his number out of your post & offer to PM anyone his number on request.
Thanks,
Matt
Posted on: 2005/5/2 23:49
wow you guys are giving me heaps of good ideas now. i have started looking for the engine(front cut) and the cheapest i can find is $2400 after read through all the posts its seems still on the high side, is there a place anyone can recommend, also i have seen a couple of engine, gearbox and loom deals for around 1500 but just a little weary with k's and also whether i might be missing that one vital bit to get it working, thanks again
Posted on: 2005/5/3 0:37
From Melbourne Vic
if you don't know exactly what you need, a half cut always will provide the reassurance that you have everything. you also learn a fair bit when you pull it all out of the front cut yourself, saves hassle of getting the bits that you are missing too. asian auto spares always have cheap half cuts, around 2000 to 2200 i think.
Posted on: 2005/5/3 3:29
From Sydney, Australia
Lagwagon - Id love to leave it ur hands for a couple of weeks .But ur in Melb.
What would you guys recomend to do urself. Remember im a builder not a mechanic....!
Posted on: 2005/5/4 14:23
From Adelaide, Australia
seriously, craig williams at maddat, he is a top bloke, He can hook you up with a crossmember if you would like to do it yourself, he can modify a crossmember to suit any engine you want and make up a gearbox crossmember to go with that too. http://www.maddat.cjb.net/
Posted on: 2005/5/4 14:36
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
« 1 2 (3) 4 »
