« 1 2 3 4 (5)
Re: VG30DETT IN A SUNNY B310
From WA
i'm still using the original BW 8
Posted on: 2005/6/1 7:49
From South Dakota USA/Trinidad and Tobago
OK KOOL.....now I know what diff I can use.I hate to bug you with more questions but what are good struts/shocks etc(suspension wise)for the car......and how is the twin turbo 1uz-fe coming along
Posted on: 2005/6/1 8:27
From WA
i THINK you can use subaru leone vented discs with the sunny hub turned down to 140mm
Posted on: 2005/6/1 8:39
what is a suitable crossmember for the sunny....that is another thing i found puzzling with the 240c.
Posted on: 2005/6/2 10:16
From WA
std crossmember. try not to cut it or you run into engineering probs.
i had to cut mine because it is 140mm deep. that's right - 140mm. NOTHING was gonna fit without cutting it - except an L24/L26/L28.
Posted on: 2005/6/3 2:51
I was thinking....like you said the 1uz will be a tight fit in the sunny...so the radiator has to be a real thin one.What would be a suitable radiator
Posted on: 2005/6/3 7:26
From WA
the stock soarer rad is pretty wide - like 710 X 450 X 40 from memory when i measured it.
maybe an N13 pulsar radiator? dunno - haven't had my head under a B310 in aaaaaaages.
you might have to have one custom made.
the 1UZFE doesn't put out much heat though - not like a rover V8 would or anything. they're very easy to cool.
Posted on: 2005/6/3 8:44
I just saw one of afracer's pics of his sr20 1200 and he has the std 180sx radiator which is fairly thin....maybe that can fit
Posted on: 2005/6/3 9:00
From Perth WA
pro-240c, i hope that isn't your 240c that I can see in the performance section of the quokka ???
Posted on: 2005/6/3 12:36
- sidewayz.cjb.net -
« 1 2 3 4 (5)
