have i found a lsd
From sydney australia
i was browsing through a wrecker today & found a h190 diff from a bluebird (910).when i did the usual test of turning an axle,it turns the same way both sides & appears to be either welded(god no) or an lsd.the problem is the housing is bent,& it will take a very big sledhammer to get that axle out to pull the centre to check.can anybody tell me if an open diff centre will act like a slipper when an axle is bent,or is this an lsd nobody has noticed because of the housing.ps i don't want the housing,so if i have to cut this up to get it out,no problems.
Posted on: 2002/8/9 8:37
Re: have i found a lsd
From Stone Age somewhere in U.S.A.
could be lsd, or it could be bound up in such a way that it acts like it is.
the H190 did come as a lsd or an open unit, so it is very possable that it really is one.
Posted on: 2002/8/10 5:02
From Melbourne, Australia
theres no way its an LSD!
where was that wrecker?
nah, just kidding,, hope its an LSD for youre sake, actually i never thought to check bluebirds for LSDs at the wrecker but i will be now :)
would i be right in saying all LSDs came out in TRXs but not all TRXs have LDSs
Posted on: 2002/8/11 3:41
wrong state rally,this one's here in sydney.it's not a trx either,as it has drums,oh well,looks like it's fool the wrecker again 'this one's bent,i'll give you $50 dollars for the centre'.
Posted on: 2002/8/11 8:21
