« 1 (2)
Re: Datsun 1200 A14 megasquirt turbo
From Brisbane
The crank trigger system gives the info on when to spark....he just runs the trigger and sensor with the pulley. magnetic signal as the pulley goes round.
A mate here in townsville runs one on his A15 EFI with Wolf3d computer.
this is a great setup mate!!!! very impressive. What compression ratio are you running? any specs on power etc
Cheers
Posted on: 2005/6/22 11:45
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
From Bridgetown, Barbados. W.I
That is awesome! i'm in the early stages of doing the same thing. what are you using to control the spark and the coil packs. bye bye distributor! i was of the understanding that the megasquirt was a fuel only computer. give us more details!!!
Megasquirt V2(squirt $ spark) can control spark with the use of a distributor.
The distributor less system is the Megaquirt 'Edis' system which uses the ford EDIS (distributor less) System.
Posted on: 2005/6/22 13:52
Life's better SIDEWAYS!!
Quite a regular
From Finland
First of all, I
Posted on: 2005/6/22 17:28
A14 Turbo Power
From Canada
Dammm Nicce.
I like it.
Posted on: 2005/6/22 20:25
Well sort of power does this setup produce?? around 160-180Bhp????
Its the best Turbo Aseries i ever seen.
Posted on: 2005/6/22 22:22
From California
and LHD too
Posted on: 2005/6/23 5:20
From California
Oops ... Double post!
Posted on: 2005/6/23 5:21
From Sydney Australia
Now that`s a serious looking set-up!!!!!
Nice job
Posted on: 2005/6/23 5:44
Normally Aspirated NO MORE !!!!
« 1 (2)
