« 1 (2)
Re: h165 diff centre question.
From Brisbane, Narangba
Yeah but the actuall flange on the diff centre is the same so he will still be able to use the ute tailshaft.
Posted on: 2005/7/5 9:51
From Canberra
my bad
The only Series 2 Bluebird wagon diferential that you need to avoid is one from a wagon that was originally fitted with a four speed manual trans. This version came with a H190 diferential, while all others had the H165 in 3.9 to 1 ratio.
If you want a touring ratio, then find a Series 1 or 2 Bluebird sedan that was originally fitted with the four speed trans. These had a H165 diferential with 3.7 to 1 ratio, all others were 3.9 to 1.
Posted on: 2005/7/5 12:10
Love your Datsun.
Treat it well.
From Toowoomba, australia
what year model where the series 2 bluebirds thinking of putting the h190 in my ute when the rotary goes in
Posted on: 2005/7/5 12:39
why go up and down when you can go round and round
The last of the Series 2 wagons were assembled in the first week of February 1985, however i believe that all of the Series 3 Bluebirds came with the H190 [subject to confirmation] The production run for Series 2 models started in June of 1983
The H190 differential will not fit your 1200 ute rear axle housing which is made for the H165.
The Bluebird rear axle assembly is significantly wider than the one in your ute, so it would need to be narrowed. Both axles are the same length, so that rules out narrowing a long side & running two short axles.
Posted on: 2005/7/5 12:47
Love your Datsun.
Treat it well.
do you know how much wider they are as i will be puttin flares on the ute
Posted on: 2005/7/5 14:12
From Canberra
I ended up getting a complete ute rear (with lowering blocks and springs, 4.11) and a spare 3.7 centre, and the speedo cable I was after, for $150
By the way, can someone give me a rough idea as to how much it would cost to get the bearings replaced in one of these diffs, the 3.7 has been sitting for a while and is a little stiff.
I might as well do the rear wheel bearings while they're out, my bro payed $60 for a VN one, would it be about the same for datto?
ps. I know I should just ask the nearest diff place, but I'm a lazy turd.
Posted on: 2005/7/15 11:20
« 1 (2)
