A series Internals: what breaks?
From VIC, bendigo.
just curious to what people have broken in there engines, weather it was from over reving or running to much boost or whatever, just handy to know when building hot engines.
what do you's think?
i personally know, the pistons arnt that great when running boost, and the gearbox coz i busted 4 so far.
Posted on: 2005/7/30 11:02
1200 Sedan.Turbo A14 drawthrough 15psi Meth inj 104rwkw
1200 coupe club car. turbo L20 drawtrough
Re: A series Internals: what breaks?
From melbourne
the only thing i used to break was the rod bolts but that was fixed with 351w ,arp, bolts. and i rev my motors hard .also if u are going for revs change the pistons to good after market ones .
Posted on: 2005/7/30 14:57
From T'ville
try to use genuine lifters
and good pistons
Posted on: 2005/7/30 18:10
From Alabama, U.S.A.
yeah ,the stock pistons cant handle too much stress. I used to have a problem with the ring lands breaking between the rings.
Posted on: 2005/7/31 2:03
Quite a regular
From West Auckland New Zealand
you guys must really rape your a series! cos i used to valve bounce my a12 and pull burnouts and i still havent killed it yet!. but its a little worn out now so im puting an a14 in with a 5spd.
Posted on: 2005/7/31 2:28
From Christchurch NZ
A stock motor doesn't have enough horsepower to hurt itself. When you start to rev past eight grand, or go over about ten psi, stock rod bolts, and pistons soon start to show their limitations.
Posted on: 2005/7/31 5:08
Forced Induction!
