Help with e-brake adjust
Quite a regular
From San Diego, California USA
Hey folks, I just want anyones opinions on this:
I was under my Datsun 210 today trying to adjust the ebrake with the adjuster that is underneath the car. I tried turning it with my hands and then pliers. That thing won't budge. And it doesn't help that the cable is twisting around too. Should I just hit it with some PB Blaster and let is set then try adjusting it?
Posted on: 2005/8/17 8:13
Re: Help with e-brake adjust
From sydney australia
there's a small locknut in front of the adjuster,it's a 10 mm spanner size,so undo this
& you should be able to adjust the handbrake.
Posted on: 2005/8/17 8:51
If you haven't already, it's worthwhile to check your rear brake shoes adjustment. As they wear, this cause the handbrake not to be as good. Adjusting the shoes will also give you a higher brake pedal.
Posted on: 2005/8/17 8:57
Quite a regular
Thanks for the replies guys.
For the rear shoe adjustments do I turn the adjuster clockwise to have the shoes contact the drums correctly?
Posted on: 2005/8/18 0:23
Yes, clockwise. Tighten it until it won't go further (takes a lot of force on the little 1/4 inch wrench). Then back off until the wheel turns freely.
Posted on: 2005/8/19 4:34
Quite a regular
Thank you guys for the information.
Posted on: 2005/8/19 17:17
