(1) 2 3 »
Turbos
From Bridgetown, Barbados. W.I
Opinions please...
Whats the most suitable turbo for an A12 turbo with a rev limit of 8500rpm, 40in 33ex Valves and fully lightened and balance bottom end????
CT26...T25....T28....TDO4L??
Boost limit is around 20psi.
Strictly Race
Cam will be regrind by Crower USA....with 260duration and 11.5lift in ex.
Posted on: 2005/7/20 13:41
Life's better SIDEWAYS!!
Re: Turbos
From Warwick, QLD
Being a 1200cc motor I'd be looking for the lowest A/R's on turbos thus spooling up quicker.
20psi you should really be looking for a ball bearing center, as no bush bearing turbos are designed for that PSI they can run it but they were excessivly quick.
I'd be looking for a GT28R which is garrets Ball bearing version of the S15 silvia's T28.
Some silvias in Australia had these turbos but were only available on the jap import s15's. Garret liked them so much they now market them
But for this turbo expect to pay roughly $1200 brand new (if your getting charged more then this see me and I'll hook ya up with one cheaper)
cheers
Damo
Posted on: 2005/7/20 13:47
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Re: Turbos
i can get a T28 nissan Turbo for 400us$.....
Posted on: 2005/7/20 15:54
Re: Turbos
From Warwick, QLD
thats sounds about right for a bush bearing centered turbo!
I'd honestly go with it unless you had alot of money to spend
Posted on: 2005/7/21 0:37
Team NEW SKOOL
Re: Turbos
no its suppose to be a T28 Ball bearing....they r reconditioned(rebuilt) turbos.
Posted on: 2005/7/21 2:09
Re: Turbos
got offered Ball bearing T3 turbo, Will this be to big for a 1300cc A12 engine???
Garrett T3
Standard Trim Turbine Wheel
.63 a/r
.60 trim compressor in a 42 a/r
Posted on: 2005/8/23 3:14
Re: Turbos
From Adelaide. SA
Hey, stay well clear of a ct26 on an a12, i have one on my ca18 motor, it works well but still a bit big. cheers. Adam
Posted on: 2005/8/23 4:20
Re: Turbos
From WA
waaaaaaay too big.
go to GTRYDAZ forums or the MRT forums and look out of a TF035HM turbo off the subaru forester - a pair of these with low klms (like 20thou) delivered to my door for $150 each.
T28 compressor - T25 exhuast housing.
Posted on: 2005/8/23 8:17
Re: Turbos
Will the same Turbos apply for an A14 engine?
Posted on: 2005/8/23 10:51
Re: Turbos
From WA
Team_dat and i are planning to put one on an A14 with a lumpy cam, so yes.
Posted on: 2005/8/25 5:30
(1) 2 3 »
