« 1 (2) 3 »
Re: Turbos
From campbelltown (sydney) australia
t28 is too big, i went in a a15 turbo ute with t28 and it didnt hit boost till 4500 rpm. was so crap.
Posted on: 2005/8/25 7:54
* caution, sunglasses must be worn to view my ca18det *
Re: Turbos
From Bridgetown, Barbados. W.I
ok guess its a T25 or a kkk turbo off a 1.8 Vw( i hear they r fairly small n spool good)
Posted on: 2005/8/26 4:37
Life's better SIDEWAYS!!
Re: Turbos
From Tamworth , NSW
i gotta forester turbo sitting in me shed doin nothin, it looks friggin tiny. thinkin bout puttin it on my car down the track once i get my injection setup back here
Posted on: 2005/8/26 11:51
Re: Turbos
From brisbane
On a A12 I wouldn't be going any bigger than the T25 from a CA18DET unless you want to rev the living daylights out of it. Damo is right re. the life expectancy of a bush bearing turbo at 20 psi. They don't like those sort of boost levels at all. Do you need to run that much boost to achieve your power goal?
Matty
Posted on: 2005/8/26 12:00
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Re: Turbos
From Northern NSW
my t25 works well on my a14......will come on boost really well....will last for a bit on 10psi but feels like it wants more at 6000rpm......
but im very very pleased with t25 on a14.......t3 is way to massive for a12.... depends what racing you are doin also ....are there alot of straights or do you want low down power......
Posted on: 2005/8/26 12:09
dato ute (see avatar)
a14 blowthrough turbo motor
Import Auto Parts
For all your jap performance parts and accessories
pm for availabilty and quotes
Re: Turbos
From Sydney
Your best turbo will be a T25/T28 off a skyline gtr, same A/R's as the CA but a totaly defferant turbo.... These little babies will pull 18psi no probs...... and if you halve the capacity of an rb26dett (twin turbo) you get 1300cc.....
You should get one of these off ebay for no more than $250US
Re: Turbos
From Northern NSW
or get one off me....lol
yeh t28 off gtr is not a bad idea.......
but again i still think it depends on the type of racing you are doin
Posted on: 2005/8/26 12:12
Import Auto Parts
Re: Turbos
its circuit racing..not much long straights. I would low down torque but still be able to keep boost at 8500rpm.
well the 20psi is just an 'idea' i looking for around 190-200 hp at the flywheel.
Posted on: 2005/8/26 13:03
Re: Turbos
From Northern NSW
man thats a fair bit of hp outa a lil a12..... id say yeh t25 or t28...both would be good.....
Posted on: 2005/8/26 13:22
Import Auto Parts
Re: Turbos
From Okinawa, Japan
I've got a pair off a 1993 GT-R pm me if you want more info.
Posted on: 2005/8/26 14:08
« 1 (2) 3 »
