(1) 2 3 »
Stuck manifold bolt.....trouble
From SE Melbourne
Hi all
I was busily disassembling my manifolds today, when I came across the evil bolt.
It's a 14mm head, but a bit rounded so the socket just slips off.
How do I possibly get it out, with drilling it out.
(click on the pic and it will get bigger)
Posted on: 2005/8/30 11:52
Mildman, Datsunless
Re: Stuck manifold bolt.....trouble
From Christchurch. NZ
Firstly plenty of penetrating oil. give it a couple of sharp hits directly on the head then try with a 6 sided 14mm socket. If it still doesn't work, then you could try hammering a slightly smaller socket on or use vice grips. Then if that doesn't work either cut the head off the bolt or drill it out. But most important of all keep your cool and work through the process.
Posted on: 2005/8/30 11:58
From SE Melbourne
Well I'm running with the first step so far, doused the bolt in penetrating oil - will let it soak overnight....then I'll take your advice and belt the bolt tommorow.
Need to get some el cheapo sockets by the sound of it to belt a smaller one onto the bolt....rather not destroy the Kincrome ones.
Thanks for the advice
Posted on: 2005/8/30 12:03
Mildman, Datsunless
don't get a too cheap socket as only a half decent one will give you enough drive, a good socket can normally handle a bit of work/abuse, plus the kincrome one should be under warranty if it breaks
Posted on: 2005/8/30 12:11
From SE Melbourne
True, trur....but would it count as abuse?
If required I'll belt the 13mm socket onto the 14mm nut....
What penetrating spray do you recommend by the way, I'm just using the 'Bunnings special' - only worth a few buck, pictured in the link below.
Piccy of penetrant
Posted on: 2005/8/30 12:17
Mildman, Datsunless
it's only abuse if you tell them what you did, but it should be ok. as for penetrating oil I use "Wurth Rost-off", "CRC 5.56", or "WD40" I couldn't tell you whether you are just paying for the name or not, but any oil is better than none.
Posted on: 2005/8/30 12:24
From campbelltown (sydney) australia
get a set of stillsens on it they undo anything as lolng as u can get at it.
Posted on: 2005/8/30 12:43
* caution, sunglasses must be worn to view my ca18det *
Use INOX, its industrial grade lubricant. Its great, got my crank pulley nut off in a jiffy with an overnight soaking.
Cheers
Dave
Posted on: 2005/8/30 13:53
From Canberra, Australia
I was gonna say vice grips.
If you get really desperate you could weld some thing on to use as leverage?
Posted on: 2005/8/30 15:02
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
From Brisbane, Australia
Are the others undone? This one is probably corroded in tight!
Simply twist the manifolds and it will either move or break.
Posted on: 2005/8/30 23:16
(1) 2 3 »
