just as nizzdat solves his static problem mine starts
i've just installed an amp to the boot of my sedan, power runs up drivers side, everything else - speaker wires, rca's, stacker lead, run up the passenger side. It's all fixed in securely, wire joins are soldered and heat shrinked, earth connections - amp and head unit, are to clean metal, even cleaned the earth's from battery to block to body .... but still get blasted buzzing thru the speakers when the engines running
i've even tried a dodgey wiring of the amp earth to the battery and the head unit to the battery .... all to no avail
the stereo had no problems before the amp went in and the only things i haven't changed are the little filters on the coil, acc circuit. The alternator's only 6mnths old and was a new one.
any additional ideas would be most greatly appriciated
