Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#11
Re: Electric gurus i need your help (beefing up spark)
sam1741
Posted on: 2005/9/16 6:43
oic, thanks a lot
i will go ground there to make better spark. :)
#12
phunkdoktaspok
Posted on: 2005/9/16 12:29
Please re-read the following and make note of the winking face and have a think about what the winking face is hinting. Quote: The best way to Beef up your spark is to make sure the coil negative has a good earth
#13
sam1741
Posted on: 2005/9/16 15:39
so... winking face = not true/ half true?
#14
B210sleeper
Posted on: 2005/9/16 22:10
you don't want to ground the distributor or the coil.
make sure the ground from he battery to the chassis is good and from the engine to the chassis. the only path to ground for the high voltage from the coil needs to be through a spark plug.
#15
phunkdoktaspok
Posted on: 2005/9/17 3:56
I would hope the distributor is well grounded, Otherwise how do you expect the coil to recieve its negative trigger.
#16
sam1741
Posted on: 2005/9/17 17:11
oh...
in that case i thinking if we ground the engine block more will it improve spark? cause like this... the positive 'head' of the plug will make electron 'jump to the 'L' shape thing creating spark so the return is from the 'L' shape thing on the spark plug to the plug and to the engine block and to the chasis and back to battery.. so if i made more ground cable to the engine block dono will it create better spark?
#17
phunkdoktaspok
Posted on: 2005/9/18 1:52
Its only going to improve if the current grounding is unsatisfactory
