(1) 2 3 4 5 »
HELP lose flywheel
From NSW South Coast
Ok guys I,m about to burn my dato. I keep spinning the flywheel of at high revs (8000 up) I know the problem is the driver missing a gear but the speedway guys get realy big revs out of these motors, why can't I. I,ve lost count of the times I've spun it lose over the past three years and I'm sick of it. Ive tried locktight both on the end of the cranksharft and on the bolts, the last time I used ARP toyota 4Age bolts and they didn,t work, Its been balanced (Twice). Anyone know what the speedway guys do I can,t keep this up. Olboy
Posted on: 2005/9/25 8:45
Re: HELP lose flywheel
From Australia/ NSW/ East Maitland
The speedway guys dont have flywheels. They are push starded elininating the need for a flywheel or drive plate, The also dont run gears its all opperated through the diff you are either in gear, or out of gear (no clutch).
Thats how the speedway guys do it.
Andrew.
Posted on: 2005/9/25 9:09
Wanted to buy
A14/A15 head..
A12 motor..
Stay classy
Andrew..
wouldn't they still need some sort of flywheel though
Posted on: 2005/9/25 9:19
Nope
the block bolts directly to a engine plate, then through a uni joint vai to a diff.
May sound weird but thats how it is uaually done.
No flywheel
No Clutch
No Starter motor
No gears
Andrew
Posted on: 2005/9/25 9:26
Wanted to buy
A14/A15 head..
A12 motor..
Stay classy
Andrew..
I wonder if you could set up a clutch on a flex plate and do away with the flywheel.
Posted on: 2005/9/25 9:32
Most Victorian Mini Sprints still run flywheels.
First make sure it is machined down to lightest you can get it.
Then when you get your bottom end balanced again get the machinist to dowel it for you. Should be good for about 10,000 rpm.
By the way, when you get it balanced also get them to do it with the clutch pressure plate fitted.
Posted on: 2005/9/25 10:12
can you tell me more about the dowling. Is it just one dowl about 5mm dia between two of the bolts. A bit like the dowl in the camsharft
thanks olboy
Posted on: 2005/9/25 10:21
From Christchurch NZ
Dowling is only extra insurance. Balancing is the best protection.
Posted on: 2005/9/25 10:47
Forced Induction!
Yep, the dowel is as you explained it.
And yes, balance is absolutely necessry, the dowels just help stop any radial movement of the flywheel on the crank.
Posted on: 2005/9/25 11:12
You could also do this, just grab yourself a Tilton 7" clutch and bolt it up.
If only it was as easy as it sounds, but can be done none the less.
Posted on: 2005/9/25 11:15
(1) 2 3 4 5 »
