« 1 ... 5 6 7 (8)
Re: Give us your dream Engine and Gearbox Datto combo !
From victor harbor
13b turbs in a 1000
Posted on: 2005/10/6 8:08
From sydney
A KB10 with a fuel injected A15 bored out to 1600cc, Toyota 5 speed and an H150 LSD bolted into the 1000 rear end.
13x7 RS Watanabes all round under bolt on flares, and some cross drilled solid rotors up front should finish it off nicely.
Posted on: 2005/10/6 10:12
From penrith
1200 sedan 13b turbs supra 5spd, vl turbo diff mini spooled, and line lockers. 10's if only it could be street registered hmmm...............
Posted on: 2005/10/6 10:21
From Brisbane, Narangba
Small block Chev prostock spec with sequentional quick shift 5speed. 400 cubes of pure grunt. Around 1000-1100hp of high reving small block. I love that sound. And the revs. Tap throttle, 9500rpm and back to idle instantly.
Posted on: 2005/10/6 11:06
From sydney
Mine will be
Posted on: 2005/10/7 0:45
Quite a regular
From WI, United States
Hmm...I don't know.
I suppose something like an SR20 anda 5-speed would be enough for me. Even the E16 in the Pulsar would be an improvement over the A15 I have :-\ Damn tractor engine.
Posted on: 2005/10/7 5:31
From Central Vic
Maybe a 240kcoupe with S15 silvia running gear mount it back close to the fire wall mount the radiator and intercooler on the angels like jap drifters
would be almost a mid mount
Posted on: 2005/10/7 6:24
« 1 ... 5 6 7 (8)
