« 1 (2)
Re: Blow through turbo setup
A carby suited malpassi never failed me to get the low pressure for idle - thats using vl pumps. Seen many a few setup exactly the same.
Never used a pre pump or surge tank. Always put a fitting straight in the drain plug of the 1200 sedan tank. Never built a track car, so never had to deal with surge problems. 1/4 tank of fuel in such a small tank never gave problems.
1200rc I do recall you malpassi was secondhand of unknown condition and failed to work. Wonder why?
Any fuel pump capable of higher than boost pressure will do the job.
Main priority is to always have fuel ready for use in the carbie.
Posted on: 2005/10/10 8:38
Not too shy to talk
From Sydney, NSW, Australia
1200rallycar wrote:
generic holley blue will cost $180 original is more like $300
fuel pressure reg $55
hobs switch $30
solenoid $20
$50
Where can I get all this stuff from? Also, what carby were you using?
Posted on: 2005/10/10 10:27
Hi i have use the vl pump both ways, with and without a sure tank both work fine. The 70 psi can be droped to about 5-6 psi using the malpassi M3T regulater. I have just sold my turbo A12 so i have 2 regs for sale, one is new it was on the car for about an hour $150 for that. still in the box.
The other was on the car when the return line got blocked, there for blowing the diapham, you can buy a new one for $40 i'm only asking $50 for this one.
send me a note if you are interested
Posted on: 2005/10/10 11:48
From canberra act
has any one here drilled a hole under the fuel pump diaphram and fed a boost line to it i have seen this done a few times
Posted on: 2005/10/14 3:25
From WA
lol sounds like something the gemini owners would do...
Posted on: 2005/10/14 6:18
How do you plan to seal the crankcase from boost pressure?
It may be possible on a chevy style pump that uses a pushrod, But a datsun lever type pump will prove very difficult to seal beneath the diaphram and still have the pump able to operate.
You could just supply the crankcase with boost and simply degrease your motor everyday
Posted on: 2005/10/14 8:20
« 1 (2)
