Stuffed igntion switch on 1200 ute. Any ideas for replacement?
Not too shy to talk
From Launceston, Tasmania
Hi,
I can get a genuine one from nissan for about $80.
But I'm feeling a bit cheap as I just unnecessairly replaced the starter motor . Are there any other options here? Is there any way to service a faulty switch? We the ute ones used on any other cars to widen my search at the wreckers?
Cheers,
Brad
Posted on: 2005/10/24 11:48
Re: Stuffed igntion switch on 1200 ute. Any ideas for replacement?
From sydney australia
stanzas & sunnys use the same switch as late utes,so have a look for one of these in a wreckers.
Posted on: 2005/10/24 12:15
Not too shy to talk
Mine is a 1972 model.
Switch has two screw lugs and is pin out compatible with a 120y switch (which is smaller and only has one lug).
Reckon stanza or sunny will fit a '72?
Thanks for your reply!
Posted on: 2005/10/24 12:24
From Melbourne, Victroria
Yes, some Sunny (Stanza) ones can do the job. (assuming it is the steering lock type)
Can help you with a 2nd hand one of those, would like to match it up with yours thou ..
Where are you??
Can you email photos??
Im in Melbourne
Simon
simon@datsunparts.com.au
Posted on: 2005/10/24 23:05
From Warburton vic
For 80bucks just buy it
Posted on: 2005/10/25 1:18
From Cyberjaya, Malaysia
just use a momentary button as a switch :D
so you'll just need to press the button to start the car
Posted on: 2005/10/25 2:58
The ignition switch should only be around $20 USD (I just bought one).
RockAuto
The key lock cylinder (keylock) is about the same: RockAuto Parts Catalog
If you need the entire keylock mechanism (cylinder & barrel), $25: ACDELCO CYLINDER,IGN LK W/ 7 TUMBLER LOCK CYLINDER
Posted on: 2005/10/25 7:25
Not too shy to talk
Thanks everyone for their comments.
I got a igntion switch form a 120y (just the switch not the lock, tumbler,etc) and found that it was completely different.
Sourced a lock, tumbler, etc from a datsun sunny. After pin punching out the two blank screws, the sunny one went in perfectly.
Cheaper than $80.
I bet it screws up next week
Posted on: 2005/10/25 11:03
From Brisbane Australia
the switch part of your steering lock is available as a non genuine part.
if you still need one pop into an auto electician
ade
Posted on: 2005/10/26 9:10
Thanks for the tip. I had no idea the B310 (Sunny) key lock assembly would bolt to the 1200 steering column.
What year is your 1200 ute?
Posted on: 2005/10/27 4:56
