140kw @ wheels 1070cc
From Tamworth, NSW
Has any one seen the zoom artical on a ke20 corolla!!! its making some serious power its running1.38bar boost. why carn't an a12 match it?
Posted on: 2005/11/4 5:52
Re: 140kw @ wheels 1070cc
From campbelltown (sydney) australia
thats because noone can justify spending huge amounts of money on a a12 motor to get that much power..... u give me an a12 ill put all my turbo parts on it and boost it to 1.38 bar and we will see if we can beat the ke20.......
Posted on: 2005/11/4 6:01
* caution, sunglasses must be worn to view my ca18det *
From Tamworth, NSW
boost is 1.24bar sorry. i am not up with cost but it seems easy enough the only work to the block is aftermarket rings and pistons so compersission is now 7.43, custom camshaft o- ringed after market pushrods an then shotpeened crank an rods the head flowed pretty well an then they slapped a hks turbo on it. is it expensive?
Posted on: 2005/11/4 6:14
From Christchurch NZ
it starts to add up pretty quick.
Posted on: 2005/11/4 8:38
Forced Induction!
The corolla engine is already a far more reliable engine than the A series from stock it was designed from scratch not a carryover from the mini like the A series is. However the A series has better head design for higher performance hands down. If the bottom end can be built right, the A series should blitz the K series engine in overall performance turbo or NA.
The same doesnt go for the L series competitor where in Puerto Rico the 3T series pushrods can reach 700hp boosted and the 3tg twin cam 12 valver can reach 800 plus.
Posted on: 2005/11/4 8:56
From Melbourne AUS
i may be wrong in this case.... but a lot of magazine articles have 'estimated' power outputs..... dont believe everything you read
Posted on: 2005/11/4 13:19
1973 B110 A12
From Tamworth, NSW
nope they dynoed this 4 sure. So does any have a guess how much boost a a12 can take with after market pistions( lowering compresion to around 8) an the same treatment to the rods an crank can take? a12's are cheap. don't matter if i kill a few
Posted on: 2005/11/4 23:44
