Yes, just get a B310 manual tailshaft. It should bolt right in.
Yes, the auto vs. manual driveshaft is different.Quote:
B310 shaft part numbers
37000-H8500 SHAFT ASSY-PROPELLER manual
37000-H8900 SHAFT ASSY-PROPELLER automatic
37000-H9200 SHAFT ASSY-PROPELLER A14E up to 7909
37000-H9201 SHAFT ASSY-PROPELLER A14E from 7910-8010 A15E from 8011
The EGI models used a two-piece shaft with center bearing, similar to the longbed GB122.
The 1971-1973 Datsun 1200 manual tailshaft is the same overall length as the B310 manual but with different bolting in back. Both should use the "Japanese" differential (H145 or H150). But take careful measurements and double-check before you buy. Nissan changed specs several times. you want to get one where you can change the back flange.
B110 and B210 use same driveshaft (except for the Aussie-built 120Y models).
I thought I heard the B210 Coupes in Australia came from Japan, so if correct they should also work with a flange change.
tailshaft comparo
