Decompresion plate???
From Tamworth, NSW
Thinking of a cheaper way to get lower compresion in an a12 rather than buying forged pistons. if i use a decompresion plate will it affect the valves??? an how strong are the standard pistons? i have heard they are a bit weak. thanks guys
Posted on: 2005/11/12 4:49
Re: Decompresion plate???
From Christchurch NZ
No it wont effect the valves.
Posted on: 2005/11/12 21:05
Forced Induction!
From Brisbane
I got mine from ACL Specialised Gaskets. Ph: 07 3365 0799 Cost about $50
Posted on: 2005/11/12 21:57
From Newcastle (NSW)
I don't think the pistons are weak, but I've never played with A12's. A decompression plate will reduce the squish clearance and may infact promote pre-ignition rather than retard it. What's the puropose ?? Turbo ???
Posted on: 2005/11/13 3:38
From Tamworth, NSW
yep a turbo. any ideas how thick i am aiming for around 7.5-8:1 comp. yep its gunna be big boost.
Posted on: 2005/11/13 22:28
From Warburton vic
Stay away from them. Decompress it properly. using a decomp plate could stuff up all the rocker geometery.
If your running big boost put forgies in it anyway. You mayaswell build it reliable
coops
Posted on: 2005/11/13 22:46
From Tamworth, NSW
cost don't forge pistons cost abit (1000+)??? yer thought the would muck up the valve train. can you buy shorter rods?? are they cheaper
Posted on: 2005/11/14 1:41
Muck up the rocker geometry? The shims come in .7mm and 1.5mm. All you do is adjust the tappet to compensate.
Posted on: 2005/11/14 7:22
Forced Induction!
