« 1 (2)
Re: Which coil to use with electronic distributer?
From Sydney.au
you should get yourself a 12V coil, if the one you are using is NOT. i originally used a mazda 323 coil for a while then went to the matching coil (which was a subaru model from the 80's) when i changed to the N12 dissy.
all the while i was using a full 12v system, without the ballast. i was originally using a JayCar HEI kit, then went full electronic ignition when I got my hands on the N13 dissy.
basically, if your coil heats up enough(too hot to touch), it is BAD. test it
Posted on: 2005/12/19 8:13
From Perth
I use a BOSCH coil HEC715 on the racecar
Works a treat
Posted on: 2005/12/19 10:58
From Sydney, Australia
I've got 4 of those on my CA18
by dattoman_1000 on 2005/12/19 20:58:35
Works a treat
Posted on: 2005/12/19 14:41
From Perth
Showoff
Posted on: 2005/12/20 11:07
Quite a regular
From Brisbane, Australia
Don't use a points coil with an electronic dizzy. They generate much higher back voltages (EMF) that can damage the dizzy electronics. You need to use a coil designed for electronic dizzy. Best to get the coil that was in the car that the dizzy came from and you know you have a matched pair. I asked Bosch if they could recommend one of their coils for use with the E15 dizzy but their response was that they did not recommend any of them. Barry
Posted on: 2006/1/5 2:03
The factory distributors do not use a capactive discharge system.
Some of the Datsun systems used a points coil with the electronic distributor. In this case, the ballast resistor is still used. With the resistor, the voltage will not be too high.
For best results with the blackbox A15 factory distributor, use coil Nissan part number 22433-H7280 or equivalent (Bosch 00200). This should work with most Mitsubishi or Hitachi distributors that don't use a ballast resistor. For a list of part numbers, see B310 Electronic Distributor Swap.
Posted on: 2006/1/5 5:18
From Bunbury Western Australia
I now have my new dizzy from datrats and went out to buy a Bosch GT40 coil got it home then was reccomended by a mate to swap it for a GT40T coil now I read on the box to use it only in a contact points ignition set up so I think I will take it back for the third time and swap it for a HEC715 coil as it is reccomended on the Bosch PDF for the nissan bluebird series 2 which is the same distributor I bought
see! http://apps.bosch.com.au/products/saa/ignition_coils.pdf
Posted on: 2006/1/5 5:56
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
« 1 (2)
